SDA 1
Hi all, first post. Can anyone identify these SDA’s? They say Sda 1 on back. I was told they are considered SDA A1. I never see these for sale anywhere, always 1B, 1C etc. Are these the original SDA’s? I’ve had them since 1988. I replaced the sl1000’s 20 yrs ago with sl2000’s. Would the RD0194’s be the correct tweeter replacement? Any info on power handling or other historic facts would be much appreciated. Thanks
Living room:
Polk SDA-1
Marantz 2385
Sony CDP-CE375
Basement:
Polk SDA-SRS 1.2
HaflerXL-600
Onkyo P-304 pre amp
Onkyo T-9090II tuner
JVC XL-Z331
Basement 2:
Rectilinear 6
Marantz 1152DC
McIntosh MR 80 tuner
Basement bedroom
Marantz 2270
Rectilinear 11 Highboy
Best Answers
  • Gardenstater
    Gardenstater Posts: 4,803
    edited April 2022 Answer ✓
    Welcome!
    Looks like the First Gen. SDA 1 to me. Those look like RDO-194s in there already, which I believe is what Polk recommends as the update to the SL1000. Are they sealing properly without enlarging the cutouts?
    The SDA Handbook is a wealth of information:
    https://us.v-cdn.net/5021930/uploads/editor/fe/zg3wih4m7prz.pdf
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,321
    Answer ✓
    The problem with going from the SL1000 to the RD-0194 is the cut out it tends to really push the connection points into the magnet assembly. Because the SL1000 connection was lower it was more in the oval radius and not affected. The RD-194/198 series is straight out to the sides. Typically you need to remove a slight amount of the tweeter hole to relieve the pressure. Usually its just a smidge maybe 1/8" or 3/16" which still should not be outside the tweeter face/bezel.
    If you've ever seen the SL2000 cut out it has two little half moon relief's right where the tweeter wires connect.
  • Gardenstater
    The SL2000 has a completely different appearance to the dome, different bezel, wires showing on front bezel. So different. See https://forum.polkaudio.com/discussion/182943/the-tale-of-5-tweeters-sda-tweeter-replacement-guide/p1
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
Answers
  • crisbep
    crisbep Posts: 5
    Hi George, thanks for your reply. I didn’t think they made the rdo194’s that long ago. My older brother gave me the tweets to upgrade from the SL1000’s. I popped one. I could swear he said they were SL2000’s. As far as sealing they are flush against cabinet and there are ports right below so I figured sealing would not be an issue. Thanks for the download also..
    Living room:
    Polk SDA-1
    Marantz 2385
    Sony CDP-CE375
    Basement:
    Polk SDA-SRS 1.2
    HaflerXL-600
    Onkyo P-304 pre amp
    JVC XL-Z331
    Basement 2:
    Rectilinear 6
    Marantz 1152DC
    Basement bedroom
    Marantz 2270
  • Gardenstater
    You're welcome and you've got a point there....in this case it might not be an issue because of those overpressure prevention ports in the upper chamber. As long as they are firmly seated you may be OK. Don't want them rattling at all whatsoever.
    These speakers were reviewed in Dec. 1982 Stereo Review:
    https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/80s/HiFi-Stereo-Review-1982-12.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • crisbep
    crisbep Posts: 5
    Thank you so much for the SDA handbook. What a wealth of info. Looks like I have first gen SDA 1 with tweeter fuses on binding post plate. I’m reading the review also. What a blast from the past with the old ads. 82 was also the year I graduated HS.
    Living room:
    Polk SDA-1
    Marantz 2385
    Sony CDP-CE375
    Basement:
    Polk SDA-SRS 1.2
    HaflerXL-600
    Onkyo P-304 pre amp
    JVC XL-Z331
    Basement 2:
    Rectilinear 6
    Marantz 1152DC
    Basement bedroom
    Marantz 2270
    xschop Posts: 5,411
    edited April 2022
    You can use a belt sander to make those plastic plates fit. Take off 0.09" from top and 0.09" from bottom. Smooth out the corners and it drops right in.
    Post edited by xschop on
    crisbep wrote: »
    When he ordered them as replacements for the sl2000 they may have said sl2000. IIRC I believe on the paperwork they are listed as SL2000.
  • crisbep
    crisbep Posts: 5
    Here’s what’s in there. IIRC I only had to drill new holes for them. They don’t have anything stenciled on them, how do you tell if they are SL2000 or RD 0194?
    Living room:
    Polk SDA-1
    Marantz 2385
    Sony CDP-CE375
    Basement:
    Polk SDA-SRS 1.2
    HaflerXL-600
    Onkyo P-304 pre amp
    JVC XL-Z331
    Basement 2:
    Rectilinear 6
    Marantz 1152DC
    Basement bedroom
    Marantz 2270
    xschop Posts: 5,411
    Wow, not even an SL1000 tweeter route-out.
  • Gardenstater
    edited April 2022
    xschop wrote: »
    Wow is right. Photo was dark and I thought maybe they painted it black I guess. It could've been a management decision based upon the SL1000 nearing its end and they knew it would piss off the customers to have to route out the baffle or cut down tweeter bezels to install an SL2000. Maybe it was just a cost saving measure since a seal wasn't critical.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • crisbep
    crisbep Posts: 5
    Hi George. I read that 5 tweeter discussion, can’t believe I missed that pic. Thanks again for the info..
    Living room:
    Polk SDA-1
    Marantz 2385
    Sony CDP-CE375
    Basement:
    Polk SDA-SRS 1.2
    HaflerXL-600
    Onkyo P-304 pre amp
    JVC XL-Z331
    Basement 2:
    Rectilinear 6
    Marantz 1152DC
    Basement bedroom
    Marantz 2270
    xschop Posts: 5,411
    Those may be 198's. Looks like they didn't bother changing the faston, instead soldered directly to dome tab?
  • Gardenstater
    xschop wrote: »
    Good catch!
    RDO-194 (same size terminals?)
    RDO-198 (clearly different size terminals)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,002
    edited April 2022
    NM
    xschop Posts: 5,411
    There's a thread here that someone made an adapter plate and just installed a single RDO in the middle.
    F1nut Posts: 52,002
    edited April 2022
    There was also a "signature" version of that model that had a plate covering the 2 holes.
    The holes are also plugged with dowel rods. Changes were also made to the inside of the cabinet.
    Copied from a thread from yrs ago.
    The difference are as follows SDA1 had ports for the top 2 MW and each had their own box. SDA1 had 3 inductors. SDA1a had no ports and the MW boxes removed SDA1a had 2 inductors and came with SL1000 and SL2000. Now here is where slight difference's came to play SL2000 SDA1a had the MW's lowered slightly to make room for the SL2000 tweeter The SDA1a with the SL1000 tweeter when you used a SL2000 or RDO-194 tweeter dome it is almost behind the top of the grill frame"
    Here's a thread if you ever want to change them.
    https://forum.polkaudio.com/discussion/55888/polk-audio-speaker-wiring-schematics-amp-more-stereo-dimensional-array-sda#latest
    Look for SDA 1 to SDA 1a conversion.
  • Gardenstater
    edited April 2022
    ^^ Pretty cool and I had never read that. So they actually had a modification kit that could be ordered. Interesting that the instructions implied that there WERE tweeter gaskets in the SDA 1 (which OP is missing). Also, I think that quote from the forum above is in error because, as far as I can tell, the SDA 1A Signature still had the 3 large inductors. The "Z-balance Network" in the low frequency module was disabled and the two 130uf caps were replaced with a 2.5 Ohm resistor in the Dimensional Driver and the Stereo Driver. The holes were plugged and the horizontal partition removed, and more Dacron was added. Cool.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Browsing craigslist this morn I just happened upon a "SDA 1" for sale which must actually be a SDA 1A with the SL1000. There sure ain't much room for a larger tweeter bezel.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,411
    Those would be a great score for someone that enjoys tweeter echo.
    I disagree with that in bold, I have a set of SDA1 signatures from the factory. They never had 3 inductors nor the midwoofer boxes inside. They also have the big plate in the back that all the crossover and binding posts and fuses are on. The SDA1a had a small round binding post cup and no fuses.
  • Gardenstater
    edited April 2022
    ^^ Well the plot certainly thickens then. I read the instructions for converting the SDA 1 to SDA 1A and it still would retain the 3 large inductors. The schematic we have for SDA 1A clearly shows that there are still 3 large inductors. The only discrepancy I saw was that in the schematic for SDA 1A it did NOT show a 2.5 Ohm resistor in place of the 130 uF capacitors, although the capacitors were removed.
    I guess the only conclusion is that the SDA 1 "Signature" was different crossovers from SDA 1A. Maybe the filename in archives for conversion from SDA 1 to SDA 1A is mislabeled as "SDA 1 to SDA 1A Signature edition.pdf" <<attn. @DarqueKnight
    So maybe there were 3 distinct models. First SDA 1, then SDA 1 Signature Edition, and then SDA 1A (with two baffle variants depending upon tweeter). All 3 have different XOs.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Yes the SDA 1 signatures were intermediate models. The brass plate covered the ports that had dowel rods glued into them. Mine also have a tweeter contouring network where one resistor has a 5.8uf cap across it. Which in the beginning I thought I could use a RD-0198 tweeter.
    I also liked the dimensional tweeter in the beginning, after about a year I understood why folks disconnected it. I'd find myself looking around the room because of the artifacts it produced. My tweeters did come with gaskets as I feel all of them should have. The gasket for the SL1000 also extended outside of the tweeter face and some may have removed them because of the look they had. (it was ugly).
  • Gardenstater
    So the schematic for the Signature Edition isn't in the archives I guess.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    No it is not. It should be the same as the 1A with the exception of 1 amp fast blo fuses instead of the polyswitches.
  • Gardenstater
    edited April 2022
    Well I'm in it now but I will try to clear it up for anybody reading this who is probably confused :)
    If you look at the 2 schematics we have, for the SDA 1 and the SDA 1A, they both show 3 MW inductors, and by that I mean the 5.6 mH inductor for the two sub bass MWs and a 1.82 mH inductor for the stereo MW and the dimensional MW. So that's 3 by my count.
    Also, neither of the schematics show a 5.8 uF capacitor in parallel with a tweeter resistor.
    So it would *seem* to me that there are more XO differences between your SDA Signature 1 and SDA 1A than just fuses/polyswitches :#
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    edited April 2022
    I made a mistake. it was the .5uf not 5.8. too early to talk tech evidently this a.m. I remember the cap just didn't remember the value.
    If I think about it after work I'll take a picture of my XO to help relive your anxiety :D
  • Gardenstater
    edited April 2022
    I hear that. What about the 3 inductors that yours "never had"?
    It's more like Engineer's OCD than anxiety :D
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Read step 4 Z-network that is what I was referring to. Mine did not come with that network. I'm assuming that was the 3rd big coil you were referring to. YES mine has the normal inductors on the board.
