Problem with the Woofer of Magnifi Max SR
Hello everyone,
I have a problem with the woofer of my Magnifi Max SR, for 3 days now.
As I am watching TV, the woofer makes noises just as if there was a firework. Did someone experienced the same? Do you have a solution ?
Thanks in advance
Mathieu
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,317
    Hello Mathieu,
    Welcome to Polk's forum. From what others have experienced that problem could be related to interference between the soundbar/subwoofer and any network routers nearby. Are you able to move the router away from where the soundbar is? Even a few feet can make the difference.
