Parasound and Hafler amps
POLKHT
POLKHT Posts: 138
edited February 2005 in Electronics
I'm thinking about purchasing one the these amps. Either a Parasound HCA 1000 or the Hafler 9180. Which one is better for my speakers. I have RTi100s. Also do they sound different?
Post edited by POLKHT on
  • steveinaz
    steveinaz Posts: 19,545
    Hafler is more comparable to Soundcraftsmen. Kind of a "work horse" amp if you will. The Parasound will most likely be a little more articulate/accurate; the Hafler, warm and laid back.
  • ckpiv
    ckpiv Posts: 35
    I have used a Parasound D/AS 1000 (130wpc into 8 Ohms) since 1988 and it has been a fantastic amp for the price. I have used it to drive SDA 2B's. I am now upgrading to the Parasound HALO A21 due to my success with my D/AS 1000 over the past 17 years. Have not heard a Hafler in quite a while so I cannot give much feed back there.
    2 ch rig:
    Parasound Halo A21 amp
    Wyred4Sound DAC2
    Audiophilleo 2
    Dodd Audio Tube Preamp
    Parasound Halo P3 Preamp
    Mac Mini + Amarra, Audirvana Plus, Pure Music
    2TB External HD
    PS Audio P3
    Rotel RCD1072 cd player
    Polk SDA-SRS 2.3 Speakers
  • shaggypud
    shaggypud Posts: 11
    I've been running a Hafler DH120 amp to drive a pair of Studio Monitor 7's since the early 80's..Still kicking and going strong.
    Just my $.02
    Good luck,:)
  • steveinaz
    If your system is sounding analytical/cold, go with the Hafler. If you are a resolution/detail geek, or have a tubed pre, get the Parasound.
  • POLKHT
    POLKHT Posts: 138
    Is the Parasound HCA 1000 any good? And how is it different from the HCA 1000A?
    Thanks for the replies.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    The A version just has the auto-turn on thing, only difference, but a big difference for some people.
    Personally, I'd hold out and get a 1500A instead, only a couple more hundred $, and ten times the amp...but that's just based on my experience...
  • outlander
    outlander Posts: 218
    A friend of mine has a 150W X 2 halfler. To me it seems a little harsh, especially at higher volumes and extended play times. The last thing you want is an amp that starts to beat you down after an hour or so. I’d go with the Parasound. Who knows mabe it's just this model, but I'd still go with the Parasound. Did you check out what Rotel has to offer?
    O
  • steveinaz
    Parasound "A" series have the 12v trigger circuit. Not a biggie.
