Perlisten Audio S7t - $20K speaker eye / ear candy
WLDock
WLDock Posts: 3,073
edited April 2022 in Speakers
  • WLDock
    WLDock Posts: 3,073
    edited April 2022
    vader540is wrote: »
    Their CEO Daniel Roemer, also help design these speakers
    https://arendalsound.com/
    https://www.monoprice.com/pages/monolithencorespeakers
    That's good to know information.
    F1nut Posts: 51,881
    edited April 2022
    The Velodyne DD15+ has a -3dB of 14.6Hz, distortion < 0.5%. The best the Perlisten can manage is in the boosted mode with a -6dB of 15Hz.
    Clipdat Posts: 13,098
    edited April 2022
  • WLDock
    WLDock Posts: 3,073
    edited April 2022
    F1, you are often on top of this stuff and you know how it goes when it comes to specs. Most times the published specs don't tell the whole story and its hard to compare one brand to the next depending on test methods. These are $6000-$8000 subs for the 1-2% crowd.
    More info is reveled when third parties test different subs using modern methods.
    Audiogon is touting the D215s as one of the best they have measured. James Larson, even stated that he thought it would surpass the DD18+. I will never claim to fully understand nor am I an expert at interpreting data. Nevertheless, here are their numbers:
    DD18+
    https://www.audioholics.com/subwoofer-reviews/digital-drive-plus-18/dd18-measurements
    Perlisten D215s
    https://www.audioholics.com/subwoofer-reviews/perlisten-d215s/conclusion
    F1nut Posts: 51,881
    As if one didn't already need a reason to ignore their ramblings they are conducting their experiments OUTDOORS! Hardly a controlled environment.
    In addition, they measured the Velodyne at two meters and the Perlisten at one meter. Pfffft!
    I'm sure you meant Audioholics. ;)
  • WLDock
    WLDock Posts: 3,073
    edited April 2022
    Yes, Audioholics! 🙂 Obviously you are not a fan.
    Near field, far field, in room, outdoor measurements....It's too much. I'm sure an anechoic chamber to measure subwoofers would be big and expensive.
    As I said, I bow out gracefully when trying to interpret data and make strong comparisons. I keep my thoughts to myself as there are so many variables, I leave it to the so called experts to make claims.
  • WLDock
    WLDock Posts: 3,073
