Best way to move L800’s on carpet
My L800’s are big… they are on medium thickness carpet and have no spikes. I slid some cardboard under them before and it worked okay but was still a lot of work, especially because one is by a corner (to some degree).
Maybe there’s an easier way.
Best Answer
Answers
    treitz3 Posts: 20,068
    Whenever I go to set up my rig in a new environment, I set my main speakers on butcher block type cutting boards. It adds weight but it makes them much easier to move, toe in, measure, etc while on carpet. As soon as I find their optimum location, I loose them and continue tweaking. FWIW.
  • tjcinnamon
    tjcinnamon Posts: 100
    Just sent an picked up some carpet sliders.
  • pearsall001
    pearsall001 Posts: 5,323
    I always use a 3/4" thick MDF cut a tad larger than the speaker base for the sliders. Speakers sit on top & make sliding around a breeze. Works great for subs also...& of course furniture. Lol!
  • tjcinnamon
    Thanks for the great advice all. The carpet sliders were a delight
    F1nut Posts: 51,915
    After you get them dialed in, spikes are a must on carpet. Make sure the spikes pierce the carpet otherwise they do nothing.
