Adding an Equalizer to an Integrated Amp
Hey all,
So I took the plunge and got the Musical Fidelity M5si, and I noticed I don't have any control of the output of the sound. I know most will say that adding an equalizer is not worth it, but sound is subjective and I'm looking to add one or find some way to control the audio a bit. I don't want to modify the whole sound signature I really just want to be be able to adjust two things.
1. I'd like to be able to fade the sound left and right. With my current set up my desk is a bit closer to the right speaker so I like to fade the sound to the right left a bit so that it's more balanced when I'm sitting there. Then I can easily center it when I'm just listening from the couch.
2. I'd like to boost the bass just a touch. I have the M5si hooked up to Polk RTi A9s and I find the bass very neutral and while I'm not at all a basshead I would like to give it a bit more presence.
What kind of product should I be looking for?
«13
Answers
    audioluvr Posts: 5,915
    edited March 2022
    A subwoofer and a dirty sock to muffle the right speaker?
    Clipdat Posts: 13,095
    You drinking before noon?
    treitz3 Posts: 19,992
    Line out into Aux2 should do it if you use an EQ (not recommended but it will do what you want it to do). You should be looking at getting a sub for the lower frequencies.
  • Lacrymosa
    Lacrymosa Posts: 43
    I would need a really big sock.
    audioluvr wrote: »
    I'd need a pretty big sock!
    Clipdat wrote: »
    It was 3pm here so he's not doing too bad by my watch.
    treitz3 wrote: »
    Any recommendations for EQs? I seem to be finding mostly car ones. I have pre-outs (and RCA cables), which should work as well I've read.
    edited March 2022
    Gotta be honest here. I haven't used an EQ in my rigs in a very, very long time. If memory serves, the one I liked the most was a Furman dual 31 band EQ. You have to get adapters for the connections but if you are going to use an EQ? Another connection won't matter. To do what you are wanting to do, you will need a dual band EQ (unless the EQ you choose has a balance knob)
    Here is one that is less than a Benjamin shipped to your door. https://www.google.com/shopping/product/1?client=firefox-b-1-d&q=Furman+dual+31+band+EQ&prds=epd:14070932293839370536,eto:14070932293839370536_0,pid:14070932293839370536&sa=X&ved=0ahUKEwis5I2Wscb2AhWhQjABHdB7DV4Q9pwGCAU
  • HzTweaker
    HzTweaker Posts: 959
    I don't know what the budget is but a Schiit audio Loki mini+ doesn't seem like a bad way to go. No balance control though.
    https://www.schiit.com/products/loki-mini-3
  • Lacrymosa
    Lacrymosa Posts: 43
    treitz3 wrote: »
    Thanks I'll look into that one!
    HzTweaker wrote: »
    Thanks, I really want the balance control most at this time though. Other EQ features are bonus.
    butterbean wrote: »
    Subwoofer!!
    lol, eventually, but not looking to buy one right now, still recovering from the M5si. And my main priority is the balance control. I'm actually surprised the M5si doesn't produce more bass in these speakers. Would a 14 gauge wire help. I currently have 16 gauge.
    What is your source? That *may* explain the lack of bass.
  • rooftop59
    rooftop59 Posts: 8,121
    I would get a minidsp with Dirac live, not an eq.
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 51,776
    Lacrymosa wrote: »
    MF gear doesn't lack in the bass department and neither do those speakers. For sure, generic 16 gauge speaker cables aren't helping, but gauge alone is no way to shop for cables.
    What are your sources?
    edited March 2022
    He mentioned earlier in another thread a turntable and also a Bluetooth receiver.
    F1nut Posts: 51,776
    Ok, I know nothing about Bluetooth receivers other than I want nothing to do with it.
  • Lacrymosa
    Lacrymosa Posts: 43
    edited March 2022
    treitz3 wrote: »
    Clipdat wrote: »
    Lol! I did away with that horrid piece. I now use an RCA cable directly from t he receiver to my phone, which has CDs losslessly ripped to it. And yes, my Project Debut Carbon turntable.
    What phone? Most phones aren't known for exceptional quality coming out of the 3.5mm jack.
  • Lacrymosa
    Lacrymosa Posts: 43
    rooftop59 wrote: »
    I shall look into this, thanks!
    Lacrymosa wrote: »
    I have to admit I DO feel a tad underwhelmed with the amp with these speakers, so maybe my Amazon basic 16 gauge wires are an issue lol? I just feel like the sound isn't THAT much of an improvement so either I expected way too much or the wires are the issue.
    I wouldn't say that there is no bass, I would just personally prefer a bit more. I think it's a tad underwhelming, again, as someone who is not a basshead.
  • Lacrymosa
    Lacrymosa Posts: 43
    edited March 2022
    Clipdat wrote: »
    It's an iPhone, but it doesn't use a 3.5mm jack, it is an RCA to lightening cable. I know people like to find an issue with the source, but I don't have an issue with the quality of the audio in my car (or my previous car), nor when I play it through the basement surround, or my headphones. So I either expected too much or there is an issue with my wiring I'm thinking.
    And the issue is still present with my turntable. The bass seems quiet. I just think with these speakers it should be much more present with the power the m5si supplies.
    So the volume output setting on the phone is set to 100% and then you're controlling the playback volume from the M5si?
    Whether or not you want to head this advice? That's up to you but you need to ditch your source being the phone. That is most definitely why your setup is bass shy.
    As for the LP player? The bass should be fine on that, if the tonearm is properly adjusted, you have an MM cartridge and are playing decently recorded music.
  • Lacrymosa
    Lacrymosa Posts: 43
    edited March 2022
    Clipdat wrote: »
    Hmmm that's a good point haha oh God... I gave it a shot, sampled a few songs, It seems it might be a bit more punchy, but I still feel like it lacks presence. Again my expectations might be too high.
  • Lacrymosa
    Lacrymosa Posts: 43
    edited March 2022
    treitz3 wrote: »
    I respect the advice and I realize I'm on a forum with people who seek pure audio quality, but the phone is more than capable of producing bass to my satisfaction through other sources. Ultimately as I thought, suggestions for changing my source and adding a sub are what I expected, but really I'm just looking for suggestions on EQs that give me the option to adjust left/right balance/fade and bass. I know it's not what people want to hear lol but I'm just adding a touch to the sound quality, and it's me who has to listen to it. (And maybe change out my speaker wires to something better)
    edited March 2022
    What is the genre of music you are using to test with?
    It sounds counterintuitive but when you move to an integrated amp like this with less distortion, sometimes the bass can sound more lean & tight as opposed to loose and boomey.
    What you might be hearing is not "less bass" but rather a higher quality low end reproduction based on the M5si's grip on the woofers.
    Then again there's a lot of variables at play here and without being there in person and checking every facet of the setup (and hearing it) it's hard for us to speculate. Can you post a photo of the rear of the M5si so we can see the connections?
  • Lacrymosa
    Lacrymosa Posts: 43
    Clipdat wrote: »
    That could very well be the case. Maybe I like the loose sound? It wouldn't say the bass is missing from the music so that seems plausible. I've been playing mostly rock, hard rock, some leaning more to metal, and some a bit more symphonic. Some songs seem to produce better results than others, so it also comes down to the recoding/mixing in some cases.
  • boston1450
    boston1450 Posts: 7,758
    Get a office chair with wheels on it & get in the sweet spot. Ditch the phone. If you need a Eq you may have the wrong integrated amplifier for what your looking to get out of it
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • dromunds
    dromunds Posts: 10,126
    You’re not adding “a touch to the sound quality” by introducing an Eq to the system you are obstructing the sound quality -the less interference with the signal the better. As F1Nut said, MF integrateds are not known to be bass shy, mine is anything but bass shy. I would definitely save up and invest in some quality speaker cables. I haven’t used an equalizer since the 80’s and never will again. I know that’s not what you want to hear but it’s adding interference to your signal path, the opposite of what you should be doing.
  • invalid
    invalid Posts: 1,456
    The problem with buying a quality amp or integrated amp is that it can make a bad source sound worse than a low quality amp does. Ditch the phone.
    At the risk of sounding stupid, the binding posts jumpers are still in place, right?
  • Lacrymosa
    Lacrymosa Posts: 43
    Clipdat wrote: »
    No, please ask, anything is helpful. They are still there yes.
  • Gardenstater
    Gardenstater Posts: 4,781
    1) How good can the DAC in an iPhone be?
    2) 16 awg cables....how long are they? That matters just as much as the gauge. I wouldn't go any smaller than 14 awg for 6 ft cables IMO.
    3) Do you have the speakers spiked to the floor or are they sitting on carpeting? That could kill the bass.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Lacrymosa
    Lacrymosa Posts: 43
    boston1450 wrote: »
    Not really a solution with my office set-up. Already have a chair with wheels though.
    dromunds wrote: »
    Thank you. I will definitely look into better cables. I believe in this amp still, based on it's reputation.
  • Lacrymosa
    Lacrymosa Posts: 43
    I know people are very focused on the bass, but is there no way for me to adjust the balance?
