Speakers that came with the WM6510 driver
Was the WM 6510 driver used in any bookshelf or center channels?
    pitdogg2 Posts: 27,349
    edited March 2022
    No and neither was the mw6510.
    I answered this question in another thread. The MW6510 was used in all the SDA, RTA speakers. The smaller speakers used MW6502, 03. I do not know personally any that used MW6510.
  • Found a 6516. Is that a good match for the 6510 or should I keep searching?
  • Gardenstater
    Gardenstater Posts: 4,804
    I very much doubt it. But we don't have the Thiele Small Parameters for the 6516, and only incomplete ones for the 6510.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,417
    6516 sounds better than a 6510, midrange wise IMO.
    F1nut Posts: 52,011
    easyrhino wrote: »
    Keep searching.
    Those AFAIK were only used in the RTA8tl and only after they went to the SL2500/3000 tweeter in those. Different XO than the RTA 8t
    xschop Posts: 5,417
    The 6516 has a tighter suspension, but about same DCR as 6510.
  • Thanks for the info, the slow search will continue:)
