Speakers that came with the WM6510 driver
easyrhino
Was the WM 6510 driver used in any bookshelf or center channels?
No and neither was the mw6510.
I answered this question in another thread. The MW6510 was used in all the SDA, RTA speakers. The smaller speakers used MW6502, 03. I do not know personally any that used MW6510. -
Found a 6516. Is that a good match for the 6510 or should I keep searching?
I very much doubt it. But we don't have the Thiele Small Parameters for the 6516, and only incomplete ones for the 6510.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
6516 sounds better than a 6510, midrange wise IMO.Don't take experimental gene therapies from known eugenicists.
Keep searching.Political Correctness'.........defined
President of Club Polk -
Those AFAIK were only used in the RTA8tl and only after they went to the SL2500/3000 tweeter in those. Different XO than the RTA 8t
The 6516 has a tighter suspension, but about same DCR as 6510.Don't take experimental gene therapies from known eugenicists.
Thanks for the info, the slow search will continue:)
