Decent right angle power cord
kevhed72
Does anyone make a nice power cord with the right-angle plug for the component end? I can not find one for the life of me....
I have searched in the past and did not find that many options. AudioQuest makes some right angle adapters but who knows how good the materials are they use. Furutech also make right angles plugs but you would have to DIY the cord yourself. The plugs are $90 for just one end plus the other side and the cost of cable.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Audioquest's adapter option. I suspect the materials they use for the Adapter are better than the hookup materials inside most equipment but not the same as those in pricey aftermarket cords. Because they sell the adapter I suspect Audioquest isn't interested in making right or left angled cords. I used to have one PS Audio made for a specific amp but that was a long time ago.
https://www.audioadvisor.com/prodinfo.asp?number=AQICE90&variation=2&gclid=CjwKCAiAvOeQBhBkEiwAxutUVN1arLr_5Hnj1FF4gx8Lfk1z3J5g9_WZfeMDvqT9Asl8dM7tUdZSUBoCsj8QAvD_BwE
I'd also consider an angled hospital grade 14/3 power cord. Those are plentiful and available from Home Depot, Amazon, etc. There are also generic right angled adapters for half what Audioquest's version costs. -
I have no idea as to quality but I believe Bottlehead.com has an upgrade angled cord.
Zu Audio offers a right angle option in their Option-Power cord. https://zuaudio.com/power-cable/option-pc-mk-i
VH Audio sells a right-angle Furutech plug (FI-12ML). I don't see it as a termination option for their power cables, but Chris might build you one with that plug if you inquire. Their Flavor 4 power cable is very nice sounding.
Quail electronics might have them. Make sure you get the dangle angle right.
https://www.quailelectronics.com/subgrouping.htm?cat=18171Aaron
Enabler Extraordinaire
