Decent right angle power cord
kevhed72
Does anyone make a nice power cord with the right-angle plug for the component end? I can not find one for the life of me....
I have searched in the past and did not find that many options. AudioQuest makes some right angle adapters but who knows how good the materials are they use. Furutech also make right angles plugs but you would have to DIY the cord yourself. The plugs are $90 for just one end plus the other side and the cost of cable.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Speakers: Golden Ear Triton Reference
Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90/JBL SDP-55
Amps: Parasound A31, A51x2
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Audioquest's adapter option. I suspect the materials they use for the Adapter are better than the hookup materials inside most equipment but not the same as those in pricey aftermarket cords. Because they sell the adapter I suspect Audioquest isn't interested in making right or left angled cords. I used to have one PS Audio made for a specific amp but that was a long time ago.
https://www.audioadvisor.com/prodinfo.asp?number=AQICE90&variation=2&gclid=CjwKCAiAvOeQBhBkEiwAxutUVN1arLr_5Hnj1FF4gx8Lfk1z3J5g9_WZfeMDvqT9Asl8dM7tUdZSUBoCsj8QAvD_BwE
I'd also consider an angled hospital grade 14/3 power cord. Those are plentiful and available from Home Depot, Amazon, etc. There are also generic right angled adapters for half what Audioquest's version costs. -
I have no idea as to quality but I believe Bottlehead.com has an upgrade angled cord.
Zu Audio offers a right angle option in their Option-Power cord. https://zuaudio.com/power-cable/option-pc-mk-i
VH Audio sells a right-angle Furutech plug (FI-12ML). I don't see it as a termination option for their power cables, but Chris might build you one with that plug if you inquire. Their Flavor 4 power cable is very nice sounding.Polk Audio first generation RTA-12s; 12 inch Polk Stands; DHS Speaker Service upgraded crossovers w/ Sonicap/Mills; the "westmassguy anti-lobing mod" (hyperdamped outer drivers/mirror imaged); tweeter anti-diffraction mod; Cardas binding posts; Neotech UPOCC internal wire; foam-lined inner driver baskets; xschop phase plugs; deleted fuses; Hurricane nuts; Sonic Barrier; Dynamat Xtreme
Quail electronics might have them. Make sure you get the dangle angle right.
https://www.quailelectronics.com/subgrouping.htm?cat=18171Aaron
Enabler Extraordinaire
