Upgrading Internal Wiring
I'm in the middle of sprucing up a set of 2b's and am thinking about the wiring from the XO's to the drivers. I bought the female push on connectors that have been mentioned a few times recently. Are you just crimping these on or removing the plastic on the connectors in order to solder them also?
What about the end that plugs on the crossover? Is there a source for the plastic plug and terminal ends (part #'s)?
Lastly, what about the wire itself? What is everyone using?
