Upgrading Internal Wiring
joebass3
I'm in the middle of sprucing up a set of 2b's and am thinking about the wiring from the XO's to the drivers. I bought the female push on connectors that have been mentioned a few times recently. Are you just crimping these on or removing the plastic on the connectors in order to solder them also?
What about the end that plugs on the crossover? Is there a source for the plastic plug and terminal ends (part #'s)?
Lastly, what about the wire itself? What is everyone using?
Crimping with a crimping tool works perfectly. I haven't tried, but I don't think you can remove then replace the plastic sleeve on the fastons.Post edited by F1nut onPolitical Correctness'.........defined
President of Club Polk -
There is a pin terminal tool for molex if needed to remove the pins
Supra rondo is great internal wiring- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I may have the tool for removing the pins. Do you have a source for the replacement pins? -
Digikey- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I purchased my parts from Mouser, but reused the board mounted sockets on my 2B's.
The pins are black in the pic, but are silver in appearance.
Pins: https://www.mouser.com/ProductDetail/571-3505501
If you choose to use these links, they are accurate to the best of my ability. I would call them to ensure these are all bare connectors that need the pins inserted.
Speaker wire to crossover connectors:
2-pin male: https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/770017-1?qs=IFMNCcK/BZzXaOQmL6U1ag==
3-pin male: https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-480700-0?qs=OSEowtgdlxKeFx1SOGZ/Ag==
4 pin male: https://www.mouser.com/ProductDetail/571-14807020
If you choose to replace the board mounted sockets.
2-pin female: https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/350831-1?qs=PYuwUcyJEnHikjRDTpH2UQ==
3-pin female: https://www.mouser.com/ProductDetail/TE-Connectivity/350760-4?qs=PYuwUcyJEnElUtumnBLMBg==
4-pin female: https://www.mouser.com/ProductDetail/571-3504301
This is what I ordered for pins.
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/60619-5?qs=pn/zyis3XjHnS7Qh4gtJXA==Gustard X26 Pro DAC
