Is my tweeter shot?
ace
Hi all. New here with a recent purchase of a Monitor 10. I think it is the original Monitor 10 with the non peerless tweeter. My tweeter from reading some materials here are the SL2500? Anyways, recently my left speaker sounded really muffled. The tweeter although dented, sounded fine until just recently. I'm not sure what that squirly thing is to the side, but noticed it came off recently. Would that have killed my tweeter or did it just went bad?
That's your voice coil lead, it's what sends the music signal through the tweeter. Yes, it needs to be connected. You could likely re-solder it.
my 3.1TLs
I will fix your shifted magnets for free.
That "squirly thing" is wire that provides electricity to the tweeter, so with it disconnected as shown in your photo, the tweeter will not function.
Well, since nobody has said so yet, those are SL2000 tweeters. Pop it out and test it with an ohmmeter.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Your Monitor 10's are not the original version, not even close. That tweeter is the SL2000 and looks like hell. If I were you I'd look on eBay for a replacement.
Welcome to Club PolkPolitical Correctness'.........defined
President of Club Polk -
wow thank you all! i will do all of the above.
Would you know which version of Monitor 10's I have? -
The last one before the Series 2.Political Correctness'.........defined
Sorry, but another question if you don't mind. I can't seem to find a replacement tweeter on ebay that's in any good shape. Would you recommend getting the RDO-194 from Polk? Also could I just replace the dome diaphragm? And if so, do you know what to search for on ebay or anywhere that would fit? -
RDO-194
Polk no longer provides tweeter.
https://forum.polkaudio.com/discussion/195946/oh-noes-rd0194-no-longer-available-through-polk-options-02-14-22#latest2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
They come up all the time, keep looking. Also, check the flea market here as I recall some were listed.Political Correctness'.........defined
Ace, where are you located?--Gary--
