Should i buy thePolk reserve r400 or upgrade the crossover for the polk csi-5 with vr3 mods?
Please let me know.
Answers
  • stangman67
    stangman67 Posts: 2,328
    Gonna need a lot more info to aid in that. Especially what your mains are and what your goal is
  • I have polk rti-12 for the front,polk rti-10 rear and my sub is gsg marty cube 18 inch run by a crown xsl-2502 in mono bridge 1550 watts in 8 ohms.the receiver is harman avr-7300.
  • stangman67
    If you are going to keep the rti-12’s, keep the csi-5 and mod it if you must. Don’t know how much you are going to gain HT wise with a crossover upgrade but trey himself will have to chime in on that one
  • Do you think is going to sound better with the upgrade?I'm going to upgrade the crossovers on the rti-12 later.
  • WLDock
    WLDock Posts: 3,073
    jorge12 wrote: »
    The older RTI are low cost decent sounding speakers that have been surpassed by many current speakers out there. Not sure how much of an improvement you are looking to get out of them. Also, what is the upgrade going to cost?
    Maybe keep what you have and save up for better LCR speakers in the future?
  • $400 For the crossover on the polk csi-5 and $750 for the crossover on the rti-12. Or wich speakers you think I should buy?
    F1nut Posts: 51,942
    edited February 2022
    This is why you should only start the thread in ONE place!!!
  • WLDock
    WLDock Posts: 3,073
    $1150 into RTi? :o
    Its your money and if you like the RTi that much then go for it.
    However.... there's high performing stuff at different price ranges these days. Also, $1200-$2000 can buy some nice speakers on the used market.
    Movies, music what are you after in the sound that you are not setting currently? What other speakers have you listened to that you like?
  • Do you guys think I should sell them and buy different speakers?I was thinking about klipsch rp8000f with the center and 2 rears for a 5.1.
    F1nut Posts: 51,942
    Do you like sharp things stuck in your ears?
  • Do you think is better to upgrade the crossovers with vr3 mods fortress plus for my rti-12 and my polk csi-5?
    Clipdat Posts: 13,100
    That depends, when was your last hearing test?
