Polk Magnifi Soundbar v2.11 - Dual Subwoofers
bljtwin
I am trying to connect two subwoofers to the same soundbar. One is the original subwoofer and the second is the same model subwoofer I got off of eBay. I have tried connecting both via bluetooth, but only one connects and the second just has the flashing light. I have tried one bluetooth and the second via the sub out on the soundbar and sub in on the subwoofer. As soon as I plug the audio cable into the soundbar sub out, it kills the bluetooth connection on the first subwoofer. Lastly, I tried connecting both subwoofers via audio cable using a y-adapter from the sub out on the soundbar. Neither subwoofer works with this configuration. Any thoughts or suggestions would be greatly appreciated!
From what I understand only one subwoofer can be connected to a soundbar.
I've heard of this working, however, what they said was, you'd have to have the one sub on and the other unplugged. Do what you did and sync the first sub, then power on the other one and it should sync. Not sure of this method, but it's just something I read.....
