New System Help
Hi
I am planning to buy a new sound system that I can use for music and for home theater.
I am thinking of using
Reciver: Sony STRDA3000ES
Front: RTi6
Center: CSi3
Surround: RTi4
Subwoofer: PSW010
Right now I am not looking for best speaker configuration but one that is good
so what do you guys think of this configuration
Thanks in advance
Front: RTi6
Center: CSi3
Surround: RTi4
Subwoofer: PSW010
Thanks in advance
Post edited by zeusthrax on
Good receiver and speaker selections. The only thing I would add is try another sub. Hsu STF-2 or SVS PB10/12 if you can swing it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
If you can spend a little more, wouldn't it be worth it to get something that would suit your needs now and in the future?
I suppose where you are going to use this system would have a lot to do with what would suit then needs of the room. Where are you planning to put this system (room dimensions and adjoining rooms would help)? -
I would at least upgrade the fronts to Rti8's.RXV1400 Yamaha Receiver
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV -
Thanks all for your suggestions. Right now i am not living in a place big enough to keep RTi8 but i am going to move to a bigger place end of this year and at that time i am thinking of getting some floor standing speaker and move RTi6 to rear and move RTi4 to side.
if you do that, you'll want to upgrade your center to match. Plus, you'd keep the 4's as surround backs (rears) and put the 6's as surrounds (sides). I'm with everyone else, I'd upgrade the sub to something a little better.Originally posted by zeusthrax
Thanks all for your suggestions. Right now i am not living in a place big enough to keep RTi8 but i am going to move to a bigger place end of this year and at that time i am thinking of getting some floor standing speaker and move RTi6 to rear and move RTi4 to side.Never kick a fresh **** on a hot day.
