Polk Model PS10 blown main amp IC
Cokey
would like to just change out this main IC with the heat sink panel. or a new power board.
should I check the on board transformer for open coil?
It's a $130.00 sub brand new. It isn't worth fixing.Political Correctness'.........defined
President of Club Polk -
That module is TDA7294, which Mouser has as part number 511-TDA7294A and sells for $3.89.
