Polk 800I
VinnyP61
VinnyP61 Posts: 28
Hello does it matter if I connect the speaker wire to the top or bottom posts on the back of the speaker in a reg hook up thanks.
Post edited by VinnyP61 on
  • juice21
    juice21 Posts: 1,866
    edited May 2002
    nope, as long as the factory jumpers are in place, both sets of terminals will get the signal...
  • mantis
    mantis Posts: 17,363
    edited May 2002
    Sounds like a bi wire comming on.
    Dan
  • STUFFMD
    STUFFMD Posts: 381
    edited May 2002
    Bi-wire those suckers, Just did it to my 800's and i can't believe the difference, cheap to do as well. Highly Highly recommend, hey if you don't like it change it back, it's only wire.
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
