SDA II price in line?
Found these locally any thoughts if they are worth it? Thanks
Check out this item on OfferUp. https://offerup.co/76sMrIPeKmb
  • la2vegas
    la2vegas Posts: 766
    They should be priced between 150 and 200 dollars to get my attention.
    pitdogg2 Posts: 27,059
    I'm sorry they wouldn't ever get my attention with the exception that I'd remove the drivers for my SDA1 Signatures.
    350 is far too high
    Toolfan66 Posts: 18,068
    edited January 2022
    Unfortunately these are at the bottom of the food chain in SDA’s, along with the original CRS’s, not highly sought after like other models, I agree on the $150-$200 range..
    They would have a better chance at $350 parting them out..
  • ramm440
    ramm440 Posts: 92
    So what are a wanted SDA or other to keep my eye out for?
    ramm440 wrote: »
    Later 4th and 5th generation of the series.
    Most any that are pin/blade interconnect.
  • ramm440
    ramm440 Posts: 92
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    Nice
    SDA SRS 2.3TL's
    SDA 2B TL's
  • ramm440
    ramm440 Posts: 92
    Can I get feed back on if these are on the most wanted list? For sda 2bs
  • dkfreebird
    dkfreebird Posts: 1,186
    Yes.Those are on the list.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    F1nut Posts: 51,787
    Those desirable 2B's look in pretty good shape. The color of the end caps is not original though.
    Those are keepers! Do all the mods and they'll be hard to beat.
  • ramm440
    ramm440 Posts: 92
    F1 kinda looks like walnut stain on original oak maybe?
    F1nut Posts: 51,787
    ramm440 wrote: »
    Yep, some dark brown stain or even black paint wiped back leaving most of the paint in the grain. Looks like crap, IMO.
    audioluvr Posts: 5,918
    I think that's walnut but someone put something on it that enhanced the grain way too much. Probably could be made better with some effort.
    F1nut Posts: 51,787
    audioluvr wrote: »
    That is oak, not walnut.
    I'm at least 50% sure it's Walnut.
    F1nut Posts: 51,787
    I'm 100% positive it is oak.
  • boston1450
    boston1450 Posts: 7,758
    Ever pound a nail into oak. Be ready for a workout :D
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • ramm440
    ramm440 Posts: 92
    Could be old english dark… that gunk will be hard to lighten without making it worse
  • So its hard to split black oak?
    F1nut Posts: 51,787
    ramm440 wrote: »
    Not a problem with the old MC paint stripper.
    boston1450 wrote: »
    Usually they bend
    ramm440 wrote: »
    Whoa, wait! No one said to take an axe to your oak end caps!
  • ramm440
    ramm440 Posts: 92
    edited September 2022
    So the seller has upped his price to 400.00 delivered to my door. It was 350.00 and I have only seen pics that I posted nothing like hands on. Oh yeah no interconnect cable either.
    Thoughts?
  • I am about to respond to him about how the magnets slide and need jb welded, new tweeters and dynamat
  • boston1450
    That's where the fun begins. 2b's are a great speaker & very affordable to upgrade. Good luck
    Randy-Maine
    by David WMG
  • Just found these locally has interconnect cable blade-pin.
    Seller Posted as sda 2 but don’t they look like sda 2b studio? Any help appreciated.rhoz5gkw1y05.jpeg
    txcoastal1 Posts: 13,513
    Pin/blade equates to SDA 2b.
  • ramm440
    ramm440 Posts: 92
    Thanks but now the owner said sorry his mistake they are blade- blade interconnect cable. Would they most likely be sda 2a or is the only true way to tell is to open them up verify 2a or 2b by seeing what numbers are printed on the driver magnets?
    Post edited by ramm440 on
  • ramm440 wrote: »
    Thanks but now the owner said sorry his mistake they are blade- blade interconnect cable. Would they most likely be sda 2a then or is the only true way to tell is to open them up verify 2a or 2b by seeing what numbers are printed on the driver magnets?
    They could still be 2B's. I bought a set of black studios very cheap and I assumed they were 2A because they were blade/blade. I was pleasantly surprised when I opened them and discovered the correct 2B drivers and single crossover board (2A has dual board crossover).
