Welborne Labs 5v Power Supply
SCompRacer
Welborne labs 5v power supply with 5v cable. $60 shipped. PP F&F or buyer add/pay percentage. I think I have Venmo too. This was powering a Squeezebox Touch. Nice shape, works. One could change the connector to power some other 5v device if it met requirements.
I tried to locate the exact output specs. IIRC it was 5v 3 amps? This was a kit I assembled.
@msg. I have one on my main touch and it makes a HUGE difference! Very tempted to grab this as a backup but trying not to be greedy…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@SCompRacer: I'm interested......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Agreed. I had one of these with my SB Touch and it was a really nice improvement.
Get it Dan!!Things work out best for those who make the best of the way things work out.-John Wooden -
Sold to Dan! Ivan gets the assist.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
This one will run my Rapsberry Pi 3B+ that has the official Pi Touchscreen + HiFiberry DAC 2 Pro DAC and a custom IR sensor + remote control."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Nice grab Dan. This should run the Pi just fine. I am keeping mine to use with a Pi Raspberry I will be building soon.
For those that have used these (or others) in the SBT, do you still get an improvement if you are already using an external DAC which is powered by a low noise power supply of its own (not from the SBT USB out)?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »For those that have used these (or others) in the SBT, do you still get an improvement if you are already using an external DAC which is powered by a low noise power supply of its own (not from the SBT USB out)?
Yes.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I think reducing noise at every stage is worth the effort. And, for a hundred bucks or so for a Teradak, seems like a no brainer.
Thanks to both of you. I already established that the SBT now draws less than 1 amp with the external DAC being powered elsewhere. I'll try another iPower for $50.George / NJ
iFi nano iDSD DAC
iPurifier3
If my memory serves me, using a scope, the OEM wall wart DC output showed a great deal of ripple when under load. The Welborne was rock steady.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Yes, and it's not subtle. I've always used an external dac with the Touch and the linear supply is so much better than cheap switching supply it's supplied with.
Just one of several posts from back in the day
https://forum.polkaudio.com/discussion/comment/1541200#Comment_1541200
