Polk Audio OWM3
Irrenhaus
Irrenhaus Posts: 1,105
Hi Everyone,
Will this work as a simple solution for an Atmos speaker? I have all Polk 7.1 setup.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    txcoastal1 Posts: 13,519
    How would these be mounted?
  • Irrenhaus
    txcoastal1 wrote: »
    Front High I guess will be the best option.
    You'll have to give it a try
    Suggestion is to get them as high as you can then tilt down...I think they will work nicely
  • stangman67
    stangman67 Posts: 2,330
    I ran owm3’s at atmos highs in my theater a few years back. Worked pretty well. Mounted them at 45 degrees facing the listener where the front wall met the ceiling
