HDMI connections for stereo listening...
nooshinjohn
In my experiment with downsizing from my Pass Labs stack to the Arcam AVR 30, I have been using HDMI connections exclusively for transmitting audio signal from my computer to the AVR. What I have found is that sonically, I feel they have performed much better than I expected. I have upgraded from basic HDMI cables to those made by Audioquest, and the higher up the food chain you go within their line of the better the audio quality is.
This afternoon my plan is to pick up a new cable and give it a spin. So far I am finding that eliminating all of that extra gear from my system has led to an improvement in the sound. I’m not certain as to why that is because the Pass X0.2 was an amazing performer in my rig. My thoughts are that perhaps all of those extra cables and components in my setup for a signal to travel may have been adding to or coloring the sound in a way that was not seen until I removed it all from the path...
Post edited by nooshinjohn on
Maybe, or maybe you want it to sound better to justify the big changes you are making. Not knowing exactly how complicated your stereo was, I can't see a pre/pro (albeit a high end one) out dueling the caliber of equipment you had in the path before2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
stangman67 wrote: »Maybe, or maybe you want it to sound better to justify the big changes you are making. Not knowing exactly how complicated your stereo was, I can't see a pre/pro (albeit a high end one) out dueling the caliber of equipment you had in the path before
I thought that, but others have heard it as well... Could be that synergy thing. I have easily eliminated more than 100 feet of un-needed wires alone. I also think the DAC sections of the Arcam are superior to those of the 8 year old PS Audio PerfectWave MkII that my signal used to pass through. Now it goes straight to the Arcam from the server.Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
