Model # of old subwoofer
Can anyone help me identify this subwoofer, I need a grill for it - the model number would be great - if possible
Thanks to you all!
Stephen
    treitz3 Posts: 20,208
    That is old school. I don't recall seeing one like that before.
    Can you not modify the pins that attach the grill to the sub and recloth it? I ask that because there is a million in one chance that a replacement grill would be available for that sub.
    F1nut Posts: 52,165
    edited December 2019
    That looks like a sub that came with one of Polk's old 5.1 systems. Have you hooked it up to see if it works?
  • verb
    verb Posts: 10,176
    Did a quick search and found this:
    Seller says is a Polk Audio DS2SW00640. Here's the link:
    https://www.ebay.com/itm/Polk-Audio-DS2SW00640-Subwoofer-USED/133152342004?hash=item1f007f7ff4:g:fcEAAOSw35ZdAXNj
    F1nut Posts: 52,165
    Good job. As I thought, it's part of an old 5.1 system that requires the proprietary power source to use. OP, that means you cannot use it.
  • FestYboy
    FestYboy Posts: 3,861
    Jesse, looks like it takes a standard IEC connection and high level inputs... It should work with any receiver.
    F1nut Posts: 52,165
    FestYboy wrote: »
    Those are outputs. The audio input is one of those multiple pin jobs.
  • delkal
    delkal Posts: 764
    FestYboy wrote: »
    Looks like F1nut nailed it. Here is a pic from the Ebay link. What was Polk thinking?
    F1nut Posts: 52,165
    Polk offered a number of those systems years ago as a solution for an easy to set up home theater rig.
    Old school HDMI.....Polk was ahead of the curve. LOL
  • boston1450
    boston1450 Posts: 7,758
    FWIW I think a new cheap sub to your doorstep would cost a tad bit more than a decent grill from Ebay. I know the PSW10's were only 99.00 years back. Happy Holidays
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    pitdogg2 Posts: 27,577
    This may help but to look at the pictures you must ba a member at audiokarma. That us a db25 connection. The whole thing might of been pretty expensive.
    https://audiokarma.org/forums/index.php?threads/polk-rmds-1-sub-box-scavange-big-iron-inside.164417/
  • stephenfromnyc
    Thanks, everyone, great feedback and yes I think the audio in is a serial port - just wanted to see if it was worth it - thinking a PSW10 might suit better
    Pretty much got it free - and audiokarma - not sure - I think I stopped by there first
  • enix_rar
    is the amplifier of a polk audio digital solutions rm-ds1 Home theater system
    currently I have not found compatible preamps
