Model # of old subwoofer
stephenfromnyc
Can anyone help me identify this subwoofer, I need a grill for it - the model number would be great - if possible
Thanks to you all!
Happy Holidays
Stephen
That is old school. I don't recall seeing one like that before.
Can you not modify the pins that attach the grill to the sub and recloth it? I ask that because there is a million in one chance that a replacement grill would be available for that sub.
That looks like a sub that came with one of Polk's old 5.1 systems. Have you hooked it up to see if it works?Political Correctness'.........defined
President of Club Polk -
Did a quick search and found this:
Seller says is a Polk Audio DS2SW00640. Here's the link:
https://www.ebay.com/itm/Polk-Audio-DS2SW00640-Subwoofer-USED/133152342004?hash=item1f007f7ff4:g:fcEAAOSw35ZdAXNjBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Good job. As I thought, it's part of an old 5.1 system that requires the proprietary power source to use. OP, that means you cannot use it.Political Correctness'.........defined
Jesse, looks like it takes a standard IEC connection and high level inputs... It should work with any receiver.
Those are outputs. The audio input is one of those multiple pin jobs.Political Correctness'.........defined
Looks like F1nut nailed it. Here is a pic from the Ebay link. What was Polk thinking?
Polk offered a number of those systems years ago as a solution for an easy to set up home theater rig.Political Correctness'.........defined
Old school HDMI.....Polk was ahead of the curve. LOL
FWIW I think a new cheap sub to your doorstep would cost a tad bit more than a decent grill from Ebay. I know the PSW10's were only 99.00 years back. Happy HolidaysRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
This may help but to look at the pictures you must ba a member at audiokarma. That us a db25 connection. The whole thing might of been pretty expensive.
https://audiokarma.org/forums/index.php?threads/polk-rmds-1-sub-box-scavange-big-iron-inside.164417/ -
Thanks, everyone, great feedback and yes I think the audio in is a serial port - just wanted to see if it was worth it - thinking a PSW10 might suit better
Pretty much got it free - and audiokarma - not sure - I think I stopped by there first -
is the amplifier of a polk audio digital solutions rm-ds1 Home theater system
currently I have not found compatible preamps
