I currently have polk 2x rti10 and receiver with Bluetooth capab
rdavila1
I am look for a powered sub and rear speakers that can run via Bluetooth. Any suggestions.?
Answers
NopePolitical Correctness'.........defined
President of Club Polk -
Tune in to the Reality Check Show with your host, F1.Don't take experimental gene therapies from known eugenicists.
I will also be upgrading my receiver. Either denon or yamaha. Not sure what model to choose yet. But would like to go with a 5.2 channel with a higher watage per.. as I will only have 2 fronts a center 2 rears and a sub.. so don't need the 7 or 9 chanel models..
If what you mean is wireless, this is quite easy for the subwoofer.
https://www.crutchfield.com/p_839SW2TRD/MartinLogan-SW2-TRD.html
Wireless surrounds are a different story, since those are usually passive and require an amp. Rocketfish has a solution, but I don't think it's that great. It's only 25w, so probably works ok only with small satellite speakers.
https://www.bestbuy.com/site/rocketfish-wireless-rear-speaker-kit/6254098.p
