SDA 2B Blade Blade interconnect
warlocks1
Just picked up a decent pair of Polk SDA 2B's with blade blade interconnect. I need a cable. I did a little research about making a interconnect, but I am still confused.
Can someone provide me directions on how to build or where to buy one.
The side panels are pulled away from the speaker, any specific glue I should use? Should I take the panels all the way off and scrape the dried glue or just re-glue?
I have been a long time member, but haven't been on in a long time.
Still own a set of 1.2TL's
Thanks,
Jeff
Thanks,
Jeff
I believe Midwest sells the cable. Yes, remove the panels, clean up the old glue then use a construction adhesive. You'll need to clamp or weigh down the panels until the adhesive cures.Political Correctness'.........defined
President of Club Polk -
Thanks I'll take a look. Been a long time I remember listening to your SDA's. You played some Dead for me,
Hope all is well -
2B with blade/blade was somewhat unusual. Apparently, Polk was using leftover stock of connector bodies.
If that was me, I'd NOT buy a blade/blade SDA cable, I'd convert the speakers to a newer connector so that an isolation transformer and non-common-ground amplifiers could be used in the future.
