Should a get a preamp or power amp?
I don't even know the difference between the two.
My setup:
Denon avr-x3500h
Polk Es60s front
Polk es30 center
Polk es20 rear
Polk HTS 12
Should I get a two-channel power amp/pre amp for music? Or should I get more channels to power the whole system?
    mhardy6647 Posts: 35,011
    edited December 2021
    What are you trying to accomplish?
    I think that's the first thing for you to decide (not us).
  • In addition to what was posted above I will ask what your budget is. You have a pretty balanced set up now that should sound pretty good for HT and music. You certainly can improve things for either music or HT, but it will take significant $$.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • DaveHo
    DaveHo Posts: 3,583
    As said above, that system is already pretty well matched. If you're looking for more, I'd opt for a 2 channel power amp to drive the 60's.
    Welcome to club Polk. We are well versed at helping you spend money!😀
