Phono Pre
xsmi
in Electronics
So, I think I'm almost at the end of my audio journey for a while, but I have nagging issue, my phono pre. I don't feel that I am getting all that my Sumiko Blackbird is laying down. I'm thinking I'd like to be at aound $1000 new, $750 used. What do you guys recommend?
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
There is a Tom Tutay built Transition Audio MC phono preamp on Reverb, granted it's above your budget, but I doubt you'll find anything close in sound for that amount. I've no connection with the seller, however.
I understand the Sumiko Blackbird is a high output moving coil cartridge which makes selection of a phono preamp easier. Unfortunately, for that cartridge I wouldn't recommend anything new for a phono preamp under around $1500 and even then the cartridge could benefit from a phono preamp double that cost. The used market may be a better choice.
What's running in the system now for a phono pre? -
Actually, I ordered the low output MC. Schiit Mani and Moon LP3.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
The Blackbird is a great cartridge. I recall it being lively sounding. I had it on a Linn LP12 with the Ittock tonearm. Some have reported difficulty in getting the optimum VTA setup.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Musical Surroundings Nova III reviewed in the current issue of TAS. $1500 is over your budget, but worth a look. Sumiko cartridges are good values. Good luck with your search.
My rule of thumb for turntable related stuff for a long time has been the cartridge and phono pre should be roughly the same MSRP and both of those are at least as important as the turntable itself. This stuff adds up!
I agree the cartridge deserves a higher quality phono preamp to get the most out of it. The low output makes that even more important. -
I have one of these with the upgraded PSU I was considering selling: https://ciaudio.com/product/peq•1-mkii-mmmc-phono-preamplifier
https://ciaudio.com/product/ac•15-mkii -
I have a Blackbird on my VPI Scoutmaster and I have an Acoustech PH-1 and think it's a great phono stage and mates well....I plan for the future. - F1Nut
I can second the Acoustech PH-1 phono pre on the used market. I've had a PH-1P for almost 20 years. Although I only use it rarely these days that's a sturdy, reliable, and quiet piece of gear.
I got real good results from the black cube!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I tried the JD9 (unmodded) and sent it back. Liked the Aragon 47K (with the standard issue power supply)...in my system. Now I have a 47K with a modified Ingot power supply.
Never heard the Acoustech PH-1, but would roll the dice on it before the JD-9.
Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
More than you were looking to spend, but the Pass Xono I have listed is end-game worthy...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
My rule of thumb for turntable related stuff for a long time has been the cartridge and phono pre should be roughly the same MSRP...
So $49.95. Got it.Gustard X26 Pro DAC
nooshinjohn wrote: »More than you were looking to spend, but the Pass Xono I have listed is end-game worthy...
I would love to have it, but I can’t spend that kind of coin.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
