XS Monitor upgrade
xschop
I put this kit together for Monitor 5 and 7 upgrade. Matching Phase plugged MW6502's, pole-pieces reset 100% concentric and Blue-loctite on magnet/pole-pieces. Self-adhesive butyl mat applied to steel basket frames also...
Billet RDO 194/198 tweeter bezels with correct stainless mounting screws and new hurricane nuts.
Midwoofer backing rings with new stainless mounting screws as well.
$235 shipped US-48 only
Just PM
Just PM
Nice!! Where have you been lately? I've missed seeing your creativity."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Man those phase plugs are legit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
NiceRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Hey Blue, not much modding lately as the plandemic had our CNC lathe down for months because a VFD took a dump. But I'm back on the grind....
I've plugged quite a few MWs now, even successfully repaired a burnt coil on one. That was fun.
Not in picture, but I have a pair of 6x6x1/2" self-adhesive sound deadening open-cell foam that go with these.Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
These are still for sale. I've figured out a way to safely pack them in a $20 Priority box.
So $200 shipped US-48 only. The RD-0194/8 plates are the last ones for the foreseeable future...Don't take experimental gene therapies from known eugenicists. -
These are NLA.Don't take experimental gene therapies from known eugenicists.
I parted the semi-rings and bezels out as a favour. So ONLY the pair MW6502's are left. I boxed them back up and will offer them for $100 shipped Priority US-48 only.
Just PM
This kit is back up for sale. I have a fresh set of MW backer rings and a new set of billet RDO tweeter plates I'm finishing up.
$200 shipped US-48
Thanks, RobDon't take experimental gene therapies from known eugenicists. -
What a freakin' awesome deal for someone with, correct me if I'm wrong, 5B or 7C and maybe Series II also?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Basically, whatever F1 says can be RDO'd.Don't take experimental gene therapies from known eugenicists.
You can’t drop in into a RTA12 nor models using the SL1000
It’s assuredly been doneCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Not true if you add a set of CRS+/SDA-2B x-overs into the equation. Eventually someone will do this to a set of 12's and experiment with tweeter placement.Don't take experimental gene therapies from known eugenicists. -
No shiteCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
As far as the MW6502 goes and one driver per speaker, in certain years: M4.5, M4, M5Jr+, M5, M7
George / NJ
iFi nano iDSD DAC
iPurifier3
Can you RDO any M4's? Would be a slick looking bookie too.Don't take experimental gene therapies from known eugenicists.
Maybe earlier M4's (kind of doubt it) but I checked the brochure and the M4 Series II had an SL1500 tweeter. Definitely looks like a smaller tweeter plate and dome too maybe. The M4.6 Series II had an SL2500 tweeter. Taller and deeper cabinet.George / NJ
iFi nano iDSD DAC
iPurifier3
Curious "About" these phase plugs, you DIYed into existing Polk Mid woofers. Is there any thread with an explanation and measurements showing what they "Do" as far as in actual usage?
I know WHAT phase plugs are, just these specifically I mean.... -
https://forum.polkaudio.com/discussion/190301/phase-plug-design-for-mw65xx/p1
They prevent the frequencies/signal at the center of the cone from cancelling and distorting.
After the mod, I found stereo imaging better improved on my monitors. I experimented with SDA-8TLs over the fall a few times and they improve the SDA imaging or soundstage imaging if you will, by more accurately syncing the inverted SDA signals.
I have a spare set of phase-plugged 6510's left over from that experiment also.
https://forum.polkaudio.com/discussion/195269/xs-6510-pair#latestPost edited by xschop onDon't take experimental gene therapies from known eugenicists. -
These are sold.Don't take experimental gene therapies from known eugenicists.
I have another one off these kits put together MINUS the 6502's
$140 shipped US-48 ONLY
If you send your MWs, I'll plug them and send everything back in some box for $150
Paypal F&F or M.O. Just PMDon't take experimental gene therapies from known eugenicists. -
Bump. Cleaning out garage. This may be the last set of plates for awhile.
Billet RDO Plates and fasteners with MW rings and fasteners and 2 billet phase plugs ... $125 shipped.Don't take experimental gene therapies from known eugenicists. -
These plates are sold.Don't take experimental gene therapies from known eugenicists.
