Should I get a separate Amp?
fdukeduong
Hey guys, I just recently built my own home theater. 3 polk Audio 265 RT for my fronts behind a 120” screen, 2 RT 65 as my surround rears and 2 in ceiling. Also running an svs 12” sub. I’m running it with a marantz SR5015 and it sounds really good. The way I’m listening to it with movies I feel I will burn out this av sooner than later. Would it be smart to get a separate amplifier or since it’s in walls that sr5015 should be enough. I’m literally a newbie to this av stuff but I managed to install and ran all the wires correctly. Even calibrated each speaker with an spl meter which makes a huge difference. Any helpful tips would be much appreciated.
Best Answer
No, you don't need an amp. Just make sure that you have plenty of ventilation around the AVR or put a component fan on it. Its plenty powerful for the setup, and even at reference level you shouldn't burn it out UNLESS those speakers are 4 ohm...
Nice system, enjoy! And welcome to club polk!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
Answers
Yes I’m using an AC infinity S10 fan placed on top of the av. It’s an 8 ohm and I’m using a 16g CLF speaker wire. My AV rack is placed in a central location with plenty of room for it to breathe. Thank you much for your input.
