filtered & unfiltered?
masterpp
masterpp Posts: 9
I have harman/kardon 630 it has PreOut for Sub. I don't know which one I should connect to on the subwoofer input. Filtered or Unfiltered? I have PSW505.
other question is, what do you normally put the setting for Low Pass on Subwoofer?
In the manual of sub, it says that I must turn OFF the subwoofer in the receiver. Should I turn Off?
I have RTi10 front speaker, CSi5 center, & RC85i ceiling.
Post edited by masterpp on
  • PolkThug
    PolkThug Posts: 7,532
    edited February 2005
    Use "Unfiltered"(LFE) input on the sub and connect an RCA cable to the sub out on the receiver. On the receiver set sub to ON, and crossover at 80Hz.
  • unc2701
    unc2701 Posts: 3,587
    BTW- in that set up PolkThug gave, the low pass on the subwoofer box won't do anything... you'll adjust the crossover point using your Harmon Kardon.
    Backburner:Krell KAV-300i
  • masterpp
    masterpp Posts: 9
    I have other receiver for my sister. it's Sony STR DB930. I can't find info if the receiver is unfiltered or filtered. Which input should I use on subwoofer psw505?
  • jarros
    jarros Posts: 84
    Filtered just means that the subwoofer will be using it's own crossover, regardless of the settings on the receiver. If you use filtered, you can use the crossover dial on the sub to select where you want to cut off the frequencies on the high end (read: whatever you set the crossover knob to, the sub will play all the frequencies BELOW that).
    Filtered is good if you're sending a FULL RANGE signal to the sub (i.e. connecting the sub directly to the stereo audio output on a DVD player). The sub will keep the low frequencies for itself and give all the higher frequencies to the other speakers in the system.
    If you're hooking up the sub to the SUB output on the receiver, the receiver is already selecting where the crossover point is going to be. Here you'll use unfiltered. If you DID put it on filtered, turning down the crossover knob on the sub will cut off all the frequencies above that crossover point, giving you a gap in frequency response. This second frequency filtration is redundant because you're already doing this on the receiver.
    Make sense?:)
    HT Setup:
    Pioneer VSX-D912K
    Polk CSi30 Center
    RM6005 Satellites (Fronts/Surrounds/Rear Center)
    Nameless 10" Sub
