Polk Legend L900 - Set to Height or Dolby Atmos Speakers?
VXR8
VXR8 Posts: 291
edited October 2021 in Speakers
Hi everyone - quick question.
I have the Polk Legend L800's arriving soon and already have the L900's. My current receiver (Denon AVC-4700) has an option to set the front height speakers to front Height or front Dolby Atmos in the configuration. The L900's are Dolby Atmos certified, so what do you believe would be the correct setting for these to gain the maximum benefit - Dolby Atmos? The configuration diagram shows the Dolby Atmos speakers sitting on top of the mains too, which is closer to where they will be, so I'll assume that will be the correct option to choose once I set it up.
Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
  • Emlyn
    Emlyn Posts: 4,620
    With a Marantz processor the front height speakers setting for speakers like the L900 supports Atmos, DTS:X and Auro 3D formats. I don’t see a difference between height and Atmos. They should be the same thing.
  • VXR8
    VXR8 Posts: 291
    Thanks for the reply and I see you already have the same front end set up. When you go into the settings and you see the "Height" speakers on the screen, they are up on the wall above the main speakers, whereas the Dolby Atmos speakers are on top of the front left and right channels, which is closer to where the L900 modules would be. I think for configuration and Audyssey set up, setting them to Dolby will actually be the way to go.
    Regards,
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • Emlyn
    Emlyn Posts: 4,620
    Got it. Might be a Denon specific thing. I would say go with the Dolby Atmos setting for the L900s. That's really what the L900s are designed for, which is to bounce the sound off the ceiling to add height to the soundfield at the listening area. I think Denon and Yamaha both had height effect speaker settings for up front prior to Atmos being introduced.
