Polk RTI series update
Did Polk ever update the RTI series speakers, or have they always been the same since inception? By update I mean changing the circuitry, drivers, tweeters etc.
Best Answer
    VR3 Posts: 29,388
    Answer ✓
    Didn't realize I was being silly.
    To my knowledge Polk doesn't usually update product lines without a major refresh. The only exception to this to my knowledge is the original lsi series. They changed the enclosure and some crossover aspects without changing model numbers and the like
Answers
    VR3 Posts: 29,388
    edited September 2021
    Original - SRT Theater System
    Series 1 - RTx IE: RT3
    Series 2 - RTxx IE: RT25
    Series 3 - RTxxi IE: RT25i
    Series 4 - RTixx IE: RTi28
    Series 5 - RTixx IE: RTi4
    Series 6 - RTiAx IE: RTiA3
  • The only sill talk is coming from you dude. A lot of speaker makers update their products all the time as technology progresses. I was looking at some bookshelf speakers the other day and the specs from the latest edition are different from the last one, as per the specs below.
    Low Frequency Driver Cast aluminium basket with a nominal 130mm (5") doped curvilinear paper cone. 25mm (1") voice coil wound on high powered
    aluminium former, with copper shorting ring. Vented and double magnet shielded
    Cast aluminium basket with a nominal 130mm (5″) doped curvilinear paper cone. 30mm (1.2″) vented magnet voice coil wound on high temperature kapton former, with copper shorting ring
    Clipdat Posts: 13,081
    LOL, he was responding to your signature quote, thinking you were saying that to him.
    VR3 Posts: 29,388
    Lol! I have signatures turned off, what is my signature?
  • Hermitism
    Hermitism Posts: 4,320
    Good catch, Drew. I can't blame the guy. Vanilla needs to make signatures smaller and use a lighter text than the actual message to help separate the two.
    VR3 Posts: 29,388
    Ohhhh yeah! Classic Doro material... Not Tom haha
