Marantz SR 5011 AVR “Monitor 2” Functions?
Kingkwas
in Electronics
Have a two TV setup for football. What are the functions of the “monitor 2” HDMI video output?
I’d like to have TV1 on Cable & TV2 on my Apple TV. Is that feasible?
So far all I can get is both TVs to mirror each other.
Any help is appreciated. Thank you.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
Best Answer
Based on what I remember and have read it's only a mirror of what the video source in main is playing. You have control over the resolution but if both are selected the lower common resolution is selected for both. If you have a 1080p projector and a 4k TV when the setup is both you'll get 1080p on them./
https://manuals.marantz.com/SR5011/EU/EN/GFNFSYmlxuhedk.phpPost edited by stevep on
Answers
I don't have a 5011, but I do have a 7011. The receiver I have can display a separate video input from Zone 2 or Zone 3 than what's selected for Zone 1 (aka the Main Zone). This is how Marantz explains it:
https://manuals.marantz.com/SR7011/EU/EN/SEHFSYauqwmsnq.php
That seems to be what you're looking for? -
The 7011 has a Zone 2 video output that the 5011 doesn't.
https://manuals.marantz.com/SR7011/EU/EN/DNTXSYultsfrsy.php
https://manuals.marantz.com/SR5011/EU/EN/DNTXSYdzwcwhty.php
The 5011 zones are audio only and the two 7011 Main HDMI outputs work the same way as the 5011.
