SDA SRS v1 - should they really sound this bad???
2
  • sbb2112
    sbb2112 Posts: 134
    I don't know if you have decided on anything but I had point to point crossovers built for my 1st gens and have both of the original crossovers. unmolested, just how they came from the factory. also have 8 sl2000's too. I offered to give them away a while ago but no takers. They needed new caps, etc but the boards are perfect. Yours for the cost of the ride from Michigan.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • kattz
    kattz Posts: 21
    edited September 2021
    PM sent - your generosity is appreciated!
    Thanks!
    Kev
    Kevin in SW Ohio
    Hardware:
    • Sansui Definition Series CA-3000 Preamp
    • Sansui Definition Series BA-3000 Amp x 2 running in mono-block config
    • Sansui TU-9900 Tuner
    • Sansui SE-9 CompuEqualizer
    • Technics SP-15 Turntable, both EPA-A250 and EPA-A501H tonearms
    • running Shure Mx97e and Pickering E610 carts on the 250, ADC XLM MkIII on the 501H
    • Akai GX635D R2R Tape Deck
    • Sony Elcaset EL-7 Tape Deck
    • Sansui SA8005 SACD Player
    • Jolida A100 Tube CD Player, tubes roled to NOS 5151 Commanders
    • DCM TF701 Time Frame speakers
    • Bowers and Wilkins DM330 speakers
    • Polk Audio SRS SDA V1 speakers
  • kattz
    kattz Posts: 21
    I was reassembling the speakers this morning and found that one passive radiator has a 3" crack from edge to edge in it. Used a little super glue to bond it but with that much vibration will not be a permanent fix.
    Observations:
    Bolts securing the end caps are tight
    There are no gaskets on the drivers or PW anywhere
    The 130uF caps on the SDA are open even though new on both crossovers.
    Kevin in SW Ohio
    Hardware:
    pitdogg2 Posts: 26,922
    Where is the crack in the passive? Can you get a picture?
    F1nut Posts: 51,668
    The stock gaskets are extremely thin.
  • kattz
    kattz Posts: 21
    No gaskets of any type. Sawdust cabinet grain painted black directly visible.
    Kevin in SW Ohio
    Hardware:
  • kattz
    kattz Posts: 21
    I'll get a picture. Unfortunately, the super glue turned the black material white. Long as the cover is on I guess no one will see it. But I know it's there.
    Kevin in SW Ohio
    Hardware:
    F1nut Posts: 51,668
    kattz wrote: »
    The gaskets will be stuck to the rim of the baskets. If there is nothing there then that's another air leak issue.
  • kattz
    kattz Posts: 21
    There truly is nothing on either the basket or the cabinet. Just one more thing to fix.
    Kevin in SW Ohio
    Hardware:
  • kattz
    kattz Posts: 21
    kattz wrote: »
    It looks like crap because of the super glue, and it doesn't look very large in the photo but it's about three quarters of an inch deep and about 2 in long from edge-to-edge right under the rubber.
    Kevin in SW Ohio
    Hardware:
    F1nut Posts: 51,668
    They've had a rough life, but I believe you are just the man to bring them back up to what they should be. For that, ye shall be rewarded.
    audioluvr Posts: 5,866
    Can you access the tear from the inside? I've used Shoe Goo sparingly to repair surrounds with success. It retains it's flexibility long after repair.
  • kattz
    kattz Posts: 21
    I can try. I should not have used super glue. The crack is mended, however.
    Kevin in SW Ohio
    Hardware:
    kattz wrote: »
    Yep super glue not the best.
    Most of us use Aleenes craft glue. I'm not sure that would be the correct glue to use there as well.
    https://www.aleenes.com/
    F1nut Posts: 51,668
    That damage is on the face of the PR not the surround, so what one uses to repair it matters less than if it was the surround.
    I would have used a vinyl repair kit, which could match the color and texture. Guys that are really good it those repairs could make the repair almost, if not entirely, disappear.
  • Nightfall
    Nightfall Posts: 10,084
    They deserve nothing less than figuring out the exact weight of the missing chunk and get out a scale to weigh your glue or vinyl repair kit material so you don't microscopically throw off the tuning.
    afterburnt wrote: »
    Village Idiot of Club Polk
    VR3 Posts: 29,384
    I don't think that damage would change the sound unless it is causing air leak
    I see some separation of the surround just to the right of it.
    audioluvr wrote: »
    Yep I'd hit that with a little contact cement on both sides let dry and push together.
    Toothpick is your friend.
  • Hi Folks
    Like kattz, I’m new here too.
    In recently considering the sale of my SDA-SRS V1s, I’ve found myself looking at upgrading them instead after having perused this forum.
    I read with great interest some of DarqueKnight’s impressive work and would like to install his style crossovers he crafted for his 1.2TLs modified for V1s, but I haven’t the cycles to dedicate to such an effort these days. Per chance I came across a less sophisticated custom crossover offering by loudspeakerchef on eBay. I wonder if he would up his game if he saw DarqueKnight’s stuff. Ready to install is my speed these days.
    DarqueKnight’s work on tweeters has me thinking about replacing my SL2000’s (which I haven’t enjoyed) with RDO194s, just in time for them to have seemly gone to unobtainium status. True?
    I wanted to follow VR3’s link posted in 2015 to have a look at the SDA-SRS modifications gathered in one place, but it is no longer viable.
    Although my V1s are intact, I’ve posted here figuring that I should follow kattz’s progress on his, as I can at least benefit from the suggestions and advice generated. That he so readily had the notion to have crossover boards spun has me wondering about the resources available for such beyond choosing a quick turn online PCB fab to have upgrade boards done. DarqueKnight clearly has that capability established for himself. I could gather the parts needed and tackle the job at a later time. The problem with that notion is that such a time would likely be too much later.
    In any case I would appreciate any comments/thoughts my post may inspire.
    Thanks!
    -Marc
    P.S. oaktreevintage.com says that the adhesive used to secure the magnet structure to the back plate of the frame in 6500 series drivers is now decades old and subject to failure from the shock of handling the speaker cabinet such as when moving it and even normal use, causing voice coil seizure and shorting. They post this note: “We now 'proactively' add 'liquid metal' epoxy to all of our Polk 6000 series drivers to eliminate the possibility (likelihood) of 'magnet shift'.” Comments please.
    Hi Folks
    Thanks!
    -Marc
    It may be better to start your own thread so not to muck up the OP's for his (speaker) problems.
    F1nut Posts: 51,668
    There is no such thing as the SDA SRS V1. It's just the SDA SRS.
  • Ok, thanks, I took my cue from the title of this thread.
    F1nut Posts: 51,668
    The RD0194 is available here, https://reconingspeakers.com/product/polk-sl1000-sl2000-tweeter/
    Midwest is sold out and apparently will not restock.
    Yes, you need to glue your magnets.
    Talk to member westmassguy about doing your crossovers.
  • invalid
    invalid Posts: 1,441
    Not trying to hijack this thread, but is polk not making the RD0194 and RD0198 tweeters anymore?
    F1nut Posts: 51,668
    Polk is no longer supporting the vintage speakers.
    nooshinjohn Posts: 25,877
    That is sad news, but what is most commendable is that they supported them for 40 years!
  • polkintheribs
    polkintheribs Posts: 4
    Thanks again. Due to the silence after my post, I did some more forum digging, which led me to contact him on my own. David (nice guy) confirmed the magnet gluing as well, something I will do immediately, whether I keep or sell them. Oaktreevintage.com doesn't reveal what adhesive they use, writing:
    "...using a 'liquid metal' epoxy, such as JB weld (but NOT 'JB Weld', as there's one that works better for a couple of reasons) around the seams between the magnets and plates..."
    I imagine they won't say if I ask them. What is the recommended epoxy? I guess one that wicks readily between parts. Although it seems straight forward, has a procedure been established?
    F1nut Posts: 51,668
    It doesn't need to wick, just needs to secure the plates and magnet. JB Weld works perfectly.
  • F1nut wrote: »
    Ok, thanks, once I pull one I expect that will be obvious.
