Maginfi max SR Most Recent Firmware Edition?
sm3lter
I have been dealing with popping from my rear speakers and since I purchased this soundbar set up earlier this year. I see that it seems to be a common issue on this forum and I have connected the setup to google home in the hope a firmware update would solve the problem.
My google home app now says that it is currently running 132, is this the most current firmware?
After doing this, now the rear speakers are super loud and the sub still pops, I haven't heard the rear speakers crackle or pop but I also have to turn them off because they are, seemingly, at full volume.
If 132 is the most recent firmware, is there anything else I can try to keep this from happening? I already moved the whole setup from my living room to get it as far away from the wifi router as possible. It is very frustrating that I traded one problem for another
PS when the sub goes off it is VERY loud and scares my 70lb dog
I'll forward your situation to a friend at Polk.
That would be amazing! This new problem is even worse than the first one, the volume of the rear speakers goes back to full when I adjust the volume of the main bar up or down. For now, they are disconnected. I'm hoping that firmware is past version 132 and the update tonight will take care of this issue.. fingers crossed
