Turntable Mounting Idea
My father is helping me build a component rack for my vintage stereo. He is an electrical engineer and has been very helpful helping me to understand all things stereo. He has also been vital understanding some of the conversations and recommendations on this site. He recommended I cantilever mount a shelf on the wall for the turntable....
What do are your thoughts concerning this? I have SDA SRS 2.3tl speakers.
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
  • TEAforONE
    TEAforONE Posts: 1,046
    I think that is a smart way to mount a TT. I really wish I had the space,and ability to move my gear to take advantage of wall mounting. Takes a bouncy floor out of the equation.
  • motorstereo
    motorstereo Posts: 2,323
    If your component rack is well built, anchored down with heavy electronics and sitting on a solid floor it isn't necessary. If you hear footfalls while playing vinyl then yes a wall mount would be a better choice
  • jbail2011
    jbail2011 Posts: 102
    Thank you for your feedback. I’ll post the project when I’m done.
    Bluesound Node 2i
  • skrol
    skrol Posts: 3,438
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol wrote: »
    That’s it!
    Bluesound Node 2i
  • Joey_V
    Joey_V Posts: 8,600
    I know 2 persons who’ve had issues with wall mounted tt shelves. I’m not sure it’s the way to go
    SCompRacer Posts: 9,090
    edited September 2021
    Joey_V wrote: »
    True, it all depends.... On a suspended floor, a load bearing wall is less likely to have issues than a non-load bearing wall. Load bearing walls will have support beneath them, either foundation or support posts.
    I recall a Greek audiophile video and he had the turntable suspended from the ceiling.
    pitdogg2 Posts: 26,984
    My last turntable was suspended from my ceiling. 35yrs ago😬
    There ya go!
  • Those wall mounted racks are great as long as it is sized correctly for your TT. You put some bolts thru the rack's frame and into the wall studs. That thing ain't going nowhere. Highly recommended!
    Hales System Two Signatures / Bryston 7B STs / McCormack RLD-1 / Innersound Phono / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • Emlyn
    Emlyn Posts: 4,657
    What's the turntable model? That's an important aspect too. If it's something that's already well isolated mechanically there may be little to gain from a wall mount shelf.
    They can be a good idea if they're mounted into a masonry wall or at least into wall studs. It may also be good to not have it mounted really close to the 2.3TLs
  • BlueFox
    BlueFox Posts: 15,251
    Back in MD in the early 70s I was living in a second floor apartment. At that time I had a completely manual AR-XB turntable, and if you walked in the apartment then the turntable skipped. I put a shelf on the wall for it, and after that it worked perfectly, and sounded great.
