Bi-wiring and more
gaborow
gaborow Posts: 16
i've got the following new setup:
Front: RTi12's
Rear: FXi5's
Center: CSi5
Sub: PSW404
HK AVR 7300
HK DVD 31
MP HTS 2500 MKII
RTi12's
CSi5
PSW505
FXi5's
Post edited by gaborow on
  • aequitas
    aequitas Posts: 77
    edited February 2005
    i think most people here are not big fans of the monster cables (do a search for that). Also there is some debate to the whole bi-wiring and whether or not it is worth it (search that too). I think what bi-wiring comes down to is personal prefrence.
    Signal Cable is good cable that is much better than monster, from my brief experience. it's hand made by frank. I got some for my fronts that really made a huge difference for the better, didnt for my rears due to cost so im just running some standard 12 awg to the rear.
    and its complicated because there are too many options.
  • HBombToo
    HBombToo Posts: 5,256
    I have some monster gear and its just under par with all my other stuff. Don't draft the check until your satisfied with your research. Please take time to enjoy the good reading in the cable swap program.
    Twin
    ***WAREMTAE***
  • aequitas
    aequitas Posts: 77
    im not saying moster cable is bad, i have a few random cables for connecting things. i think for the money there is better though. just my opinion. everyone's ear hears things differently and thats why there are debates about what is good.
  • Frank Z
    Frank Z Posts: 5,860
    Carol SuperFlex 12 ga from Home Depot. Buy enough to bi-wire if you must.
  • mantis
    mantis Posts: 17,380
    The amount of money your willing to spend on monstercable, I believe you can do better then that. Nothing wrong with Monstercable and if you can get great deals on there stuff well thats hard to beat.
    If you want better performance and are willing to spend a few pennies more let me make to following suggestions.
    Kimber Kable makes killer speaker wires. For your speakers I suggest the 4pr 4pr bi wires. For the rears I would use KWIK 16.This is wonderful inwall speaker cable and will provide great sound quality for your rear speakers. No need to run the same wire as up front to the rears.Just wire thats not going to change the sonics of the signal or run them like the fronts will. You can however use the same wire as up front but could be very costly for not much gain.
    Interconnects I suggest you use the PPj's and Timbres.These interconnects are excellent sounding and are well built. Again nice level for the kind of speakers you own.
    Good luck,
    Dan
    Dan
  • gaborow
    gaborow Posts: 16
    thanks again for the feedback...
    HK AVR 7300
    HK DVD 31
    MP HTS 2500 MKII
    RTi12's
    CSi5
    PSW505
    FXi5's
