Tsi 500 Tweeter protection
fhiggins
Does the Tsi500 have tweeter protection (fuse?) I may have blown the fuse
Or did I blow the tweeter?
There isn't a tweeter fuse. Either the tweeter has been damaged (most likely) or the crossover has been (less likely) or (even less likely) both are damaged. It would be best to contact Polk at: 1-800-377-7655 for assistance.
I did and Thank you!
And like many things these days, the tweeters are on back order. Anybody have one for sale?
Most sites are saying this tweeter is discontinued. Polk says about 4 weeks but aren't taking orders. Repair? Any help with this would be appreciated.
Find someone local selling a TSi100 for cheap like this and then take the tweeter out: https://www.ebay.com/itm/124721365485
Is it compatible. There is another one selling a tweeter says will work on Other Tsi models but not the 500.
Have you done any troubleshooting? Are the plates between the binding posts present and secure? Have you checked for loose or disconnected wires? Have you swapped the suspect tweeter with the functional one?
Swapped tweeters and yes. The good one worked in place of the bad one on the offending speaker, thus ruling out other issues.
