Yamaha RX-V775 owners
doggie750
doggie750 Posts: 1,160
Any Polks owned/ own this AV?
Got me one and would need your guidance the best way to set this up. Not familiar with Yamaha other than the R1 motorcycle! LoL
I believe “Pure Direct” would be the best way to go. Using a amp to fire the center.
Like to set all speakers to small unless you advise otherwise. Using a SPL meter and calibrate it manually.
Any advice would be great! Cheers
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    For music I’d recommend pure direct, maybe not for movies. I would use the YPAO auto eq to set the levels and then set all speakers to small if driven from the AVR. If you’re including an external amp or only powering the mains then you could set to large.
  • doggie750
    Audio tested and all good. Video input seems a concern, sometimes it’s passing through and often it doesn’t. Hope it’s only a setting that I need to figure out.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    pitdogg2 Posts: 27,244
    Could be a cable issue. What cable you using.
  • doggie750
    HDMI
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    Alright I had that all figured out already, so what brand of cable, is it 4k compatible? Is the receiver set to bitstream or ?
  • doggie750
    HDMI provided by Comcast. I’ll troubleshoot it again and change the HDMI. I am not streaming 4K, using my son’s Xbox360 to test all the HDMI inputs.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • doggie750
    Damn… still nothing but using the ROkU sticks works! Gotta be some setting. Also, where’s the Auto Format Decoding? Should I just set it on Standard?
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • doggie750
    Got the AFD, it’s the “Straight” setting. PS3 and Roku works! XBOX360 still not reading it…. Da heck. All cable works.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • Milito
    Milito Posts: 2,003
  • I’d try a full reset.
  • doggie750
    edited August 2021
    All good except Xbox360, weird. It was working fine then just stopped loving the Xbox360.
    How do I get to use the component video? Got cable input and output using AV2, should work but no signal other than the Coax audio cable. Any thoughts?
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
