Yamaha RX-V775 owners
doggie750
in Electronics
Any Polks owned/ own this AV?
Got me one and would need your guidance the best way to set this up. Not familiar with Yamaha other than the R1 motorcycle! LoL
I believe “Pure Direct” would be the best way to go. Using a amp to fire the center.
Like to set all speakers to small unless you advise otherwise. Using a SPL meter and calibrate it manually.
Any advice would be great! Cheers
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
For music I’d recommend pure direct, maybe not for movies. I would use the YPAO auto eq to set the levels and then set all speakers to small if driven from the AVR. If you’re including an external amp or only powering the mains then you could set to large.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Audio tested and all good. Video input seems a concern, sometimes it’s passing through and often it doesn’t. Hope it’s only a setting that I need to figure out.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
HDMIGodspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
HDMI provided by Comcast. I’ll troubleshoot it again and change the HDMI. I am not streaming 4K, using my son’s Xbox360 to test all the HDMI inputs.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Damn… still nothing but using the ROkU sticks works! Gotta be some setting. Also, where’s the Auto Format Decoding? Should I just set it on Standard?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Got the AFD, it’s the “Straight” setting. PS3 and Roku works! XBOX360 still not reading it…. Da heck. All cable works.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Did you download the manual?
https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-v775/downloads.htmlYamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
I’d try a full reset.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
All good except Xbox360, weird. It was working fine then just stopped loving the Xbox360.
How do I get to use the component video? Got cable input and output using AV2, should work but no signal other than the Coax audio cable. Any thoughts?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
