What model are these? 21.5 x 10.5. How do I tell L/R?
BigDA
BigDA Posts: 3
Best Answers
  • la2vegas
    la2vegas Posts: 768
    Answer ✓
    Your second picture indicates that they are model 5B. There is no right or left until you place them .
    F1nut Posts: 52,244
    Answer ✓
    Monitor 5B with the nasty SL2000 tweeters.
Answers
  • BigDA
    BigDA Posts: 3
    Thanks for the quick response. I grabbed these for $50, was wondering about the tweeter...is the tweeter worth upgrading?
    pitdogg2 Posts: 27,687
    BigDA wrote: »
    yes you can buy the RD-0194 replacement tweeter. Try Polk customer service first they may have some, if not you're left with Midwest Speaker as the place to buy.
    audioluvr Posts: 6,037
    And they probably won't seal right unless you replace the 4 missing screws out of the passive radiator
    F1nut Posts: 52,244
    There's no screws missing, that's the way they came.
  • smglbrth
    smglbrth Posts: 1,502
    Yup...
  • BigDA
    BigDA Posts: 3
    So will replacing the tweeter not be an easy swap and drop?
    F1nut Posts: 52,244
    Swap them with the RD0194... easy peasy.
