WTB: Monitor 10 drivers good or frozen
As the title states I'm looking for Monitor 10 drivers.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
  • DaveHo
    DaveHo Posts: 3,481
    There were numerous different ones used over the years. What part number is stamped on the ones you are looking to replace?
  • bored184
    bored184 Posts: 324
    Mine came with mw6500s. The problem is someone has gotten into these so I don't know what's original or not.
  • Gardenstater
    Gardenstater Posts: 4,189
    Compare the dates on the drivers with each other and with the dates on the crossovers. If they are all the same or close, then you have your answer.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Faustin
    Faustin Posts: 1,149
    What model Monitor 10's are they. What tweeter do they have? 10a's typically used the 6500 and Peerless
  • bored184
    bored184 Posts: 324
    Short story. I picked up 3 monitor tens the other day. Two I'm pretty sure are early 10s because they have the foam gasket around the drivers and passive. The other is labeled 10a. All three have peerless tweeters. In one of the monitor 10s someone replaced the original drivers with Realistic drivers. A third driver had voice coil damage. Someone must of spun the magnet when it shifted.
    I need atleat two MW6500 with gasket or 3 MW6500 without.
  • Faustin
    Pm me if interested. I have 1 available without the thick cardboard gasket, so it is probably second generation 6500.
  • Faustin
