SC07 to SC1522
doggie750
doggie750 Posts: 1,160
First of, hope all is well POlKs! Been unplugged for awhile here. Miss this forum, been hectic on my end.
Anyways, gonna upgrade my HT and thinking of purchasing this used SC1522 on sale locally. The dude is selling it for $300 without a remote, 14days to return if it fails.
I downloaded the app so I am going to try it today! Please advise for any thoughts and concerns about swapping my SCs, worth it?
Anyways, will keep u posted! Cheers.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
  • Hermitism
    Hermitism Posts: 4,333
    I think that model was part of the time frame that suffers from the ue22 error code. Might want to do some research on that over on AVS. Does the back of the unit have a manufacture date? 2011-2012?
    http://www.avsforum.com/forum/90-receivers-amps-processors/2066818-ue22-error-master-thread-pioneer-you-listening.html
    "After researching, analyzing, and hypothesizing the cause of the UE22 Error and through a diligent community effort here on AVSForum the cause of UE22 Error has been found. The root cause has been isolated to defective Texas Instruments DSP chips that globally affects all Pioneer and Pioneer Elite receivers manufactured in 2011/2012."
  • doggie750
    Thank you for that Critical Information, definitely would verify that. Will keep u guys posted!
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • DaveHo
    DaveHo Posts: 3,582
    I've had a 1523 since new. Nary an issue. The app is pretty good. I use a harmony remote with mine. Does everything I need.
  • doggie750
    Darn it… it’s manufactured in 10/2012. Gotta research if there’s a fix on this one.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    pitdogg2 Posts: 27,236
    doggie750 wrote: »
    You'll end up spending more than 300.00 if there is.
  • la2vegas
    la2vegas Posts: 767
    doggie750 wrote: »
    Steer clear...
