manually update
Mhmd
hi guys is there anyway to update my polk soundbar manually.. cant find anything in posts here
What does the manual say?Gustard X26 Pro DAC
i mean my sound bar still on 112 version as i see there’s new update but nothing new on my system .. also it’s connected with google home wifi .. but still won’t update.. i need to know how to update manually -
Usually the manual will say something like power + volume down will do a factory reset which will update it to the newest version once it's reconnected to wifi. Updates should be automatic if it's connected directly to your router via wifi. Do you have the app downloaded on a smartphone? Is it set to auto update? Again if all else fails do a factory reset and start over.Gustard X26 Pro DAC
what app? i only have google home connected -
Does it control your soundbar? If so check your settings for it to see if you have updates set to auto. Seriously, Google is your friend... and the manual.Gustard X26 Pro DAC
no there’s no option for auto update only some settings and the version .. in google homeDoes it control your soundbar? If so check your settings for it to see if you have updates set to auto. Seriously, Google is your friend... and the manual.
