manually update
hi guys is there anyway to update my polk soundbar manually.. cant find anything in posts here
    audioluvr Posts: 6,007
    What does the manual say?
  • Mhmd
    Mhmd Posts: 4
    audioluvr wrote: »
    i mean my sound bar still on 112 version as i see there’s new update but nothing new on my system .. also it’s connected with google home wifi .. but still won’t update.. i need to know how to update manually
    edited July 2021
    Usually the manual will say something like power + volume down will do a factory reset which will update it to the newest version once it's reconnected to wifi. Updates should be automatic if it's connected directly to your router via wifi. Do you have the app downloaded on a smartphone? Is it set to auto update? Again if all else fails do a factory reset and start over.
  • Mhmd
    Mhmd Posts: 4
    audioluvr wrote: »
    what app? i only have google home connected
    edited July 2021
    Does it control your soundbar? If so check your settings for it to see if you have updates set to auto. Seriously, Google is your friend... and the manual.
  • Mhmd
    Mhmd Posts: 4
    audioluvr wrote: »
    no there’s no option for auto update only some settings and the version .. in google home
