I need a rack…
jbail2011
What do you recommend? I have my 2 channel gear and my a/v gear to consider. The beast is on top of the warped cabinet in the picture below. This piece came with the house and it is visibly bowed. The a/v stuff is a Yamaha receiver, Xbox and such. I was thinking 2 racks or a double rack. Looking for ideas. I would love the a/v stuff behind glass. Thank you in advance.
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
Bluesound Node 2i
Salamander Synergy Triple. Their racks can be customized. How much money you got to spend?
https://www.audioadvisor.com/prodinfo.asp?number=SMKSLC20&opt=2534|2536
Might I recommend Selma Hayak...
nooshinjohn wrote: »Might I recommend Selma Hayak...
Always a favorite!Salamander Synergy Triple. Their racks can be customized. How much money you got to spend?
That’s 1400 more than I want to put into this. Nice though!
Bluesound Node 2i -
Yeah, I think I paid half the current Salamander price for mine about 20 years ago. I’ve taken it apart and moved it half a dozen times and it still looks new.
Check your local Craig's list, Facebook Marketplace and thrift stores!
People are practically giving them away here. I in fact gave mine away.
Nobody ever called, even at 20.00. So I tried giving it away and about the 4th person who showed up "in person" took it and loves it.
There was one person who had "2" BIG glass " open shelved units for free. 2 of them.
Anyway, there's been a lot of entertainment cabinets for cheap the past year. A LOT.
Good luck.
Search "TV stand".
Not bad for 45.00 vvv
https://wilmington.craigslist.org/fuo/d/wilmington-tv-stand/7326965441.html
I don’t know what kind of esthetics your after, but for a low price very solid stand,I can highly recommend the Monoprice ,Monolith 4 Tier Audio Stand XL. I purchased 2. I had some specific wants. I wanted more than one shelf height at approximately 9” I also wanted taller bottom legs, I also had an idea about vibration isolation for my TT. With the unused shelves and hardware,I was also able to have 3 amp stands,which are all be used. Here are some pics that I posted previously in another thread.
See my profile for list of gear. -
I’ve seen a few things on Pinterest I would like when I take over another space in the house to expand to seven channelsSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I recommend cinder blocks and 2x6's.Gustard X26 Pro DAC
I have an SRA. If you can find one used, you will be very pleasantly satisfied.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Build one yourself.If you can't hear a difference, don't waste your money.
PintrestSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
