iTunes and new laptop
simm
I have an iTunes account that was set up probably 10-12 years ago using a sign an email address I no longer have access to. It has not been an issue until now but I am moving from a windows based PC to a Mac. I burned all my CD’s, approx 1400, onto the hard drive in Apple lossless format. I have back up copies. I just bought a new laptop- MacBook Pro- and want to copy over the music I have using a new iTunes account. Is this possible? I don’t want to go through the next year burning CD’s again if I can help it.
Can't you just copy the files to a directory and tell iTunes to use that directory?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I’m not sure. I’m going to try that but didn’t know if someone had a similar situation and if so did it work. I’m also not sure how the music I have saved in iTunes will work with Apple Music has replaced iTunes.
I haven't used iTunes in ages, but I think it should work like Bud mentioned above - just copy the files to the new computer.
You might consider setting up iTunes first if you plan to use the default directories as the storage location for iTunes music files. I have my stuff stored in a few different locations. Either way is fine, you just have to tell iTunes where to find the music if not in the default folder.
CDs you rip through iTunes shouldn't have had any DRM. I think DRM is only for stuff you buy through iTunes. That stuff would be tied to your Apple ID.
Side note, if you haven't already thought about it/aren't already doing it, you might consider getting a common service email address through Google, Outlook or Yahoo. They'll never go away, unlike work or ISP email accounts. Well, Google and Outlook, at least.I disabled signatures. -
I’m going to try it in the morning. I now use a gmail email address so no issue with losing access again. Thanks -
This should work:
In the Music app on your Mac, choose File > Add To Library or File > Import. If you selected “Copy files to Music Media folder when adding to library” in Files preferences, you see File > Import. Locate a file or folder, then click Open. If you add a folder, all the files it contains are added to your library.
https://support.apple.com/guide/music/import-items-already-on-your-computer-mus3081/mac2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
If the files are already on the new computer, does opting "Copy files to Music Media folder when adding to library" create a second copy of the files in the iTunes/Music app's default library folder?I disabled signatures.
I got it all moved over onto the new laptop. Having always been a windows user there was a bit of a learning curve with the Mac but I think I am going to like it. I lost about a quarter of my album artwork but am working on manually adding them back. Should have it back up and running by the weekend. Thanks for the help.
Isn't there a way to tell iTunes to go out and pull down album art? It's been so long, I forget.
Yeah, macOS can seem a bit counter-intuitive at first, but it does have some really nice features unavailable in Windows, like Mission Control - primarily Expose and Spaces, not to mention a much cleaner all around presentation than that tablety kiddy build, Win10. Both platforms have their benefits. I got my first MacBook Pro in 2008. I still think Finder sucks.
For me, Mac's for play, Windows is for work, though I did use my MBP more for work in a previous job and ran VMware Workstation for using Windows inside macOS. Truly the best of both worlds.I disabled signatures. -
What are the best settings on a MacBook pro for using as a music server? What would be a good music management software program to use? I have always just used iTunes so not familiar with any other options. Thanks
