Monitor 5b grill peg replacement?
barrettwilt
Hi- total newbie here. I bought a pair of monitor 5bs from Goodwill but during shipping all the pegs from the grills were sheared off. The grills are in good shape but the part that is attached to the enclosure is just broken clean off. I will attach photos showing what I mean.
Is there a good replacement available? Maybe from Parts Express? I’ve tried to find out in my own but if the knowledge is already out there I thought I’d ask.
Thanks!!
Thanks!!
They are available on fleabay:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=polk+grill+peg&_sacat=0George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
IIRC, the ones at PE don't match exactly, but will work. Good luck trying to get the broken bits out.Political Correctness'.........defined
President of Club Polk -
Drill a small hole in the broken plastic bits, thread in a screw, yank with pliers. They should pop out without too much difficulty.
Be aware that Polk used 2 different sizes of round grill pegs with Christmas tree attachments. Most Ebay sellers don't know which ones they are selling. (Ask me how I know.) Best to measure one of your unbroken ones.
The smaller ones are typically used on the newer-style beveled cabinets. Earlier speakers use the ones with larger diameter.
(Earlier, still, uses a larger jelly bean-shaped peg that looks very different. Earliest of all, uses a hard plastic velcro-like pad.) -
Are your monitors labeled 5B's in the pics? I'm going to make some replacement spuds out of billet for my 5B's this weekend.Don't take experimental gene therapies from known eugenicists.
Newb here too. And realize this is an old post but the most effective way to remove is to carefully tap a thin straight head screwdriver under the tab of each side of the grill peg. They will pop right off just do it methodically. You will not damage your speaker. Just did all 8 on 5b’s and worked perfectly.
Btw you cannot push them into the cabs there is no thoroughfare.
This is a great forum have learned a lot.
Bought a pair of used 5bs recently they weren’t a 10 dollar garage find but cheap enough. Just redid one crossover and am replacing one tweeter with what I thought was original sl2000. I pulled the other tweeter and it is clearly the sl2000 but it is marked with a back original printed sticker as an sl1000! So, the tweeter confusion lives on! -
I used the ones from Parts Express on my Monitor 5B. I think it was the smaller ones.Stan
Main 2ch:
HT:
Other stuff:
