Signa S2-no sound
Mike123
Got an S2 to use with a new LG OLED TV. It worked for two days (connected via ARC) then stopped. Can’t get any sound out of it. Sound works on TV’s internal speakers.
Any troubleshooting ideas?
Thanks.
Thanks.
Answers
Probably a good way of testing the soundbar would be to use another source as a test. Maybe a portable CD player connected using the 3.5mm input on the bar. Or if you have a source device that uses a digital Toslink cable. That way you can see of the problem is the soundbar or not.
Try toggling the ARC in the LG's settings OFF and ON, I have to do it with my Samsung all the time.
Signa S2 worked great on HDMI ARC for two days, then quit. Works fine on Bluetooth. Troubleshooter on Samsung TV said bad HDMI cable. Replaced with new HDMI cable, nothing. Turning TV off and back on gives me speaker option of Receiver (HDMI Arc)-my Signa S2-but when I select it, it disappears and defaults to TV speakers.
Thought I'd try a third new HDMI cable next.
TV is new Samsung UN58RU7100 -
New HDMI cable no help.
Can no one reply? -
Had an older Samsung tv and it was fine with my Polk soundbar HDMI connection, got a new Samsung TV and it worked for a couple days, then disappeared. It connects via bluetooth but not HDMI, it's as if the Samsung TV can no longer detect that it has an audio device attached. Did you ever resolve your issue?
I am experiencing this same issue. Was a fix ever determined, or is there a way to push a hard reset? Sound works on bluetooth but it doesn't come through on hdmi.
I called their customer support and after some TV settings changes I was able to get my sound bar working. Took less than five minutes.
Good, I'm glad it was resolved.
No sound signs 2 checked settings Can’t see problem
Problem solved plcpolk
